Inventor to Plant 3D through PCF (isogen) files (Post#1 Skey)
aprajapati3C
Message 1 of 15
aprajapati3C
In our company we do piping model in inventor and until now we were doing the isometrics manualy in autocad. Now we are in process of implementing plant 3d to extract the isometrics. This is done through pcf / isogen files. So it is very important that the pcf files exported by inventor has very comprehensive information (which it doesn't). You can compare the PCF files generated by inventor and Plant 3D of same piping and see the difference. I am planning to post series of threads on this topic so that we can discuss each issues on separate posts.
In this post i want to talk about SKEYs (e.g. blind flanges). In Plant 3D we can type in (makeup) any SKEY we want. In Inventor we have very limited list of SKEY to select from. See below SKEY used in Plant 3D (FLBL). FL for flange and BL for blind.
Now see below options given in Inventor. There is nothing related to blind flange (or any kind of flange). Doesn't make any sense.
Considering that both the softwares are from autodesk we should expect some kind of symmetry between the two.
Selecting SKEYs from a drop-down list is a good idea. This helps us to decide which SKEY to use, specially for the users who are new to these softwares. But atleast we should have matching SKEYS in both softwares.
And if possible, Inventor should also have an additional option to just Type-in any SKEY we want.
Let me know if i am doing something wrong.
Replies (14)
Message 2 of 15
gcoombridge
I work on piping projects using both Plant3D and Inventor (though I heavily favour the latter). I've only tried the isogen export once and wasn't impressed - I usually approach the issue by simply documenting stuff I do in Inventor and likewise in plant.
If you're into automation I'm sure you could generate your own more comprehensive PCFs... It doesn't seem like a complex format.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 3 of 15
gcoombridge
Totally agree with being able to add custom SKEYS. Seems like a very easy improvement
Message 4 of 15
aprajapati3C
@gcoombridge Thanks for agreeing with my approach and suggestion.
What i am trying to do here to create the inventor library (as close as possible) compatible with Plant 3D. So the PCF files does not require any editing after i generate it. I want my workflow to be like,
Step-1: Generate PCF files from inventor.
Step-2: Go to Plant 3D and use "PCF to Pipe" command to generate the model.
Step-3:  Check and solve any leaks. Add field welds, supports, etc..
Step-4: Generate Isometric.
Message 5 of 15
A.Acheson
It seems when you place flange as custom the type and Skey are there. I am not sure how you are meant to get these values entered on a new part author.
Regards
Alan
Message 6 of 15
gcoombridge
If you open a PCF with notepad there's not that much to it... you could edit the fields or replace to give you the same SKEY's. Not a great solution but a VBA script in excel would do it...
Message 7 of 15
aprajapati3C
@A.Acheson i noticed that the required type and skey doesn't appear for ipart with single port.
so its there for non-ipart and
ipart with 2 or more ports.
i think this needs to be fixed.
@gcoombridge yes it can be done but good to have a permanent solution.
Message 8 of 15
CGBenner
@aprajapati3C
Hello!
Please continue these discussions, this is good stuff.  But you may also want to (if you have not already) post your suggestions in the Inventor Ideas forum, to get them in front of the Inventor development team more quickly.  You could then use these posts in this forum to ask people to go vote for your ideas.
Chris Benner
Message 10 of 15
CGBenner
@aprajapati3C
Awesome!  Thanks for sharing the link!
I used Tube & Pipe for years, but never did anything with Isogen.  I'll be watching these posts with interest!
Chris Benner
Message 11 of 15
Yijiang.Cai
Tracked as [INVGEN-74929], which is being worked in progress, and will keep you updated. Thanks!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 12 of 15
aprajapati3C
Thanks @Yijiang.Cai
Message 13 of 15
Nathan.KnightJKC2P
Observer
Observer
Hi all,
Wondering if there was any progress on this and if there is now an easy way to convert Inventor PCF files into Plant 3D without modifying the PCF manually in between?
Cheers,
Nathan
Message 14 of 15
Yijiang.Cai
@Nathan.KnightJKC2P this has been implemented in Inventor 2026, and you could have a try. Thanks!
River Cai
Autodesk, Inc.
Message 15 of 15
johan_degreef1
There is also a software from Smap3d, which has its own PID software, but uses it to generate inventor assemblies and ISOGEN isometrics in 1 go.
https://www.smap3d.com/en/
Does anybody have experience with it?
