- Mute
- Permalink
- Report
How can i rename and then edit "Object Defaults (ISO) - 3DA" to "Object Defaults - 3DA" in Inventor both locally and in style library?
The attached image "Object Defaults.png" shows the Autodesk Style Library Manager. I believe "Object Defaults (ISO) - 3DA" is marked red due to a mismatch in filecontent when I compare my project Design Library and Inventor standard Design Library. I can easily fix this by renaming "Object Defaults (ISO) - 3DA" to "Object Defaults - 3DA" in my personal design library. The problem is then, how do I find and rename the same style locally in Inventor? When I enter my drawing template (.idw) and search under "Object Defaults" in "Style Editor" nothing is apparently visible. (see "Style and Standard Editor (Library - Read-Write).png".) Why is it now visible for me to edit? All other styles are visible, and I can edit them as I please.
The image "Standard.png" is just an example of what I am trying to do. By renaming all the ISO-styles locally in Inventor and the saving to my personal style library after I try to keep everything nice and tidy with original standard styles and my own personal styles all in one library. I wonder if I even need to edit the files ending with 3DA as when in part modelling og assembly the standard that these templates try to reference might be dependent on the original name of a style. So, if I change a name of a style it will simply ignore it and look for the original file. Does anyone know anything about this? My thought was to test it out, if I could figure out how to edit "Object Defaults (ISO) - 3DA" locally.
Emil Juul Møller
