inventor studio textures "Matt Color"
rodrigue.richalland
rodrigue.richalland
hi,
I need to make somes renders of my designs but i dont know how it's possible to adjust the roughness of the textures. Do you have an idea ?
with solidworks visualize it look like this
Gabriel_Watson
Try adding bumps to your custom appearance:
leblanc2024
Hello @rodrigue.richalland,
You will need to create a custom colour using the Appearance Editor...
Once you choose the colour then select Bump.  You can adjust the coarseness and style of appearance.
Then once the choice is made you can adjust the settings to get the desired affect.
Hope this helps.
Ivon
"You don't know if you can unless you try!"
Bill_Bogan1
Hi Rodrigue,
You need to modify the Appearance assigned to the part. Here are some steps to follow:
 Feel free to ask questions if more detail is needed.
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
rodrigue.richalland
Thanks everyone for your reply
