Inventor Forum
Inventor Studio - Rendered images pixelated
6 REPLIES 6
1560 Views, 6 Replies
I have been rendering parts from this same file for about a month with no problems at all.  This morning as I went to render an image they showed up pixelated and very poor quality.  I then noticed that Ray Tracing works perfectly within Inventor but when I switch to Inventor Studio it looks terrible.  I changed the Studio Lighting Styles and it did nothing to improve the quality.
I included the assembly file, a pdf with images showing the issue and a video to illustrate the sequence.  I really appreciate any insight with this issue.  I need to get this project to the printer!
Thank you,
Patrick
Thank you,
Patrick
Labels (1)
6 REPLIES 6
SharkDesign
SharkDesign
Two potential issues
1) your rendering quality is set to low in studio.
2) you've got it on full whack but not rendering it for long enough
  Expert Elite
  Inventor Certified Professional
  Expert Elite
Here are the setting I am using for the image.
This is the result after 1000 iterations.
Is there an additional rendering quality setting that I am missing?
SharkDesign
SharkDesign
That's different. In inventor you are using draft, in studio you are using high.
I've had a lot of issues with high quality and transparent Windows. If you set that to draft does it look alright?
  Expert Elite
  Expert Elite
johnsonshiue
johnsonshiue
Hi Patrick,
It is possibly a bug or a hardware limitation. Please share the entire assembly (iam and ipt files). I can work with the project team to understand it better.
Many thanks!
Software Test Engineer
Hi Patrick,
Many thanks!
SharkDesign
in reply to: johnsonshiue
SharkDesign
Your part isn't that complicated so 9 minutes is probably fine. But you
could try setting it to 20 mins instead of 1000 iterations and see if it's
better.
  Expert Elite
better.
  Expert Elite
I have no idea what was going on.  I restarted my computer 3 times, rendered 2 different parts and turned off the camera visibility within Studio and it is now working again.
Thank you all for the help but it must have just been a temporary bug.
