Inventor Stress Anaysis
While working with Stress Analysis I decided to run a simple test to compare to an analytical result.  So I modeled a simple rod, 1" diameter, 10" OAL, A36 steel, fixed on one end with a 100 lbf load on the other.  A simple cantilever.  Analytically, I calculated a max stress of 10.2 ksi and a max deflection of 0.0088".  Inventor shows a max stress of 9.61 ksi and a max displacement of 0.0214".
I am curious why there is a significant difference?  Did I set the study up wrong or is this just the difference between analytic and numeric modelling?  Or is there another reason?  I'm trying to get a better understanding of what Stress Analysis can and cannot do.  Does anyone have any insight?
I'm running Inventor Pro 2020.2.1 on Windows 7 Pro, Intel Xeon chip with 32.0 GB of RAM.
JDMather
Can you Attach image of your hand calculations and your *.ipt file.
The results should be close on something as simple as your beam.
andrewdroth
Using this I get a deflection of 0.02341
https://www.engineeringtoolbox.com/cantilever-beams-d_1848.html
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Thanks for taking the time to respond.
As you requested:  my hand calculations and the part I modeled.
If I messed up my Mechanics of Materials calculations I'm going to be embarrassed.
andrewdroth
I think on the deflection equation the 8 should be a 3.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
JDMather
This one was for a metric problem using a different material, but as @andrewdroth indicated - check your formula for displacement.
That's just a little embarrassing.  Might be time for some new glasses.
Thanks for taking the time and effort to answer.
But there is still a significant difference between my calculations and the FEM.  I just wish I knew why; then I would be better equipped to understand what the FEM was telling me.
Thanks again for the help.
I also don't understand why this thread was marked "solved" by someone other than me?
