- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I would request for guidance and suggestion on the following stress analysis case. Please bear with me I am only sharing the images of the simulation. I will try to be precise as possible. The issue here is that the minimum safety factor is low and or decreases as I do any refinements.
Case: I am trying to simulate stress analysis case in Inventor 2014 for the shown model(Fig. 1 and Fig 2 is the actual/real case-attachment). There is a belt(not included/unnecessary for the simulation here) that is lifting at the two shackles on either side. The shackle is connected to the bolts, which is connected to the support ring. This support ring is bolted/fixed to the lifting body.
Setup: I have defined a fixed constraint on the face (lifting body) as shown in the fig.3. The loads are acting on either side of the shackles(i.e.,belt lifting) with magnitude of 177 lbforce each side as shown by the display(yellow arrows) fig 4. The material defined is steel. The contacts are bonded ( chose automatic, default). Mesh settings default.Post simulation, the results are shown in figure 5 and 6 displaying min. safety factor and Von Mises stress.
Goal: To achieve min. safety factor of 1 or more.
Real case: This part can lift good weight of more than 500 lbs. Also the support ring will produce a twisting force upon load. Now I do not know if Inventor can simulate such scenario (I am newbie to the software). I did run few cases with sliding/No Separation contacts for the bolt and the ring support but was not lucky. The min. SF kept decreasing. Tried h-refinements- no luck. Seems like a simple study but I am missing may be on the contacts or constraints if that is making all the difference.
Any suggestions or advice would be of great help and much appreciated. Feel free to discuss.
