Inventor Stress Analysis - how to report the scale of Adjusted deformation in images?
- Mute
- Permalink
- Report
When using the Inventor Stress Analysis environment, viewing results with the Adjust Displacement Display feature (Actual, Adjusted x 0.5, Adjusted x1, etc), is there a way to view the scale factor used for the 'Adjusted' results?
Obviously Adjusted x1 is exaggerated compared to Actual, and I presume the exaggeration factor varies every time, perhaps being computed automatically to give a result that clearly shows the deformation on-screen. It's a nice feature but I would like to see what factor is being used in a result I'm looking at.
I don't need to change it, I would just like to be able to report, for instance, "Images are displayed with displacements drawn as 2.53 x Actual", or whatever the number is for the particular Adjustment chosen.
The hover-over tip for the feature (image attached) helpfully shows the difference between 1:1 and 5:1 exaggeration but the drop-down scale selector pictured doesn't seem to exist as a feature in the UI.
Currently using Inventor Professional 2024 release 2024.1.1
