Inventor stopped working, now can't reinstall it
patrykstolinski
Message 1 of 36
patrykstolinski
today I launched my computer and while Inventor worked flawlessly yesterday, today it didn't open. Fusion 360 opened without issues. For inventor, I only saw the splash screen, then nothing. I've dug around the internet and did a clean uninstall, deleting anything I found about it. The error code I get when trying to reinstall is 1603. It's absolutely crazy, I downloaded IO uinstaller to clean everything up, uninstalled all the c++ visual I found, all the other autodesk apps I found, nothing bites. Slowly going crazy, I changed nothing from yesterday to today in my system or otherwise.  I also tried both downloading the files and web install. No idea what happened - normally when something doesn't work I can retrace where I messed up, but I honestly did nothing to affect Inventor in the slightest, didn't install anything apart from 'treesize' app to check some files.
Here's the log file:
2019/4/24:17:30:10	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:30:10	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:30:10	Pats	PATS-PC	Current Directory I:\Inventor_Pro_2020_English_Win_64bit_dlm
2019/4/24:17:30:10	Pats	PATS-PC	Launch
2019/4/24:17:30:10	Pats	PATS-PC	CommandLine
2019/4/24:17:30:10	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp
2019/4/24:17:30:14	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:30:12	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:30:12	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:30:12	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp
2019/4/24:17:30:12	Pats	PATS-PC	Launch
2019/4/24:17:30:14	Pats	PATS-PC	PageOpen	LaunchDialog
2019/4/24:17:30:16	Pats	PATS-PC	PageOpen	LicenseDialog
2019/4/24:17:30:18	Pats	PATS-PC	PageOpen	ProductInfoDialog
2019/4/24:17:30:18	Pats	PATS-PC	PageOpen	InventorFlavorSelectionDialog
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==DefaultLanguage:	en-us
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==InstallName:	INVENTOR
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ProductName:	Autodesk Inventor 2020
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==DisplayName:	Autodesk® Inventor® 2020
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==DeploymentName:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SetupTitle:	Autodesk Inventor 2020
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ConfigTransform:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ExeParams:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ProductCode:	{7F4DD591-2464-0001-0000-7107D70F3DB4}
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SupportLink:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==InfotainmentLink:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==MsiFileName:	inventor.msi
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==AdminImageConfigName:	Imgx64
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==AdminImageRoot:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==GetBaseDeploymentName:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==DeploymentLocation:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==DocumentLink:	https://www.autodesk.com/inventor-install-2020-enu
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==InstallDeploymentShortcut:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ModifyDeploymentShortcut:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SetupLockType:	2
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SetupNetworkType: 	0
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SystemLocale:	1045
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==EvalMsiFilePath:	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\SetupRes\eval.msi
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==EulaPath:	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\EULA
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==InstallLogPath:	C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==ConfigFile:	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\Setup.ini
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SetupPath:	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==NetworkLogPath:
2019/4/24:17:30:18	Pats	PATS-PC	Inventorui==SourceRoot:	I:\Inventor_Pro_2020_English_Win_64bit_dlm\
2019/4/24:17:30:20	Pats	PATS-PC	Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2019/4/24:17:30:20	Pats	PATS-PC	PageOpen	ProductSelectionDialog2
2019/4/24:17:30:23	Pats	PATS-PC	PageOpen	FullProgressDialog
2019/4/24:17:30:23	Pats	PATS-PC	SetupUiUtil::IsDriveSSD: path is J:\Program Files\Autodesk\
2019/4/24:17:30:24	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2019/4/24:17:30:35	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2019/4/24:17:30:35	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86) Update 4	Succeeded
2019/4/24:17:30:36	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2019/4/24:17:30:46	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2019/4/24:17:30:46	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64) Update 4	Succeeded
2019/4/24:17:30:47	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2013.log
2019/4/24:17:31:02	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2019/4/24:17:31:02	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2019/4/24:17:31:03	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2013.log
2019/4/24:17:31:21	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2019/4/24:17:31:21	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2019/4/24:17:31:21	Pats	PATS-PC	Installing Universal C Runtime (KB3118401): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2019/4/24:17:31:21	Pats	PATS-PC	Universal C Runtime (KB3118401) return code: 0
2019/4/24:17:31:21	Pats	PATS-PC	Install	Universal C Runtime (KB3118401)	Succeeded
2019/4/24:17:31:22	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2017\vc_redist.x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2017.log
2019/4/24:17:31:35	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x86) return code: 0
2019/4/24:17:31:35	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x86)	Succeeded
2019/4/24:17:31:36	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2017\vc_redist.x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2017.log
2019/4/24:17:31:50	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x64) return code: 0
2019/4/24:17:31:50	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x64)	Succeeded
2019/4/24:17:31:51	Pats	PATS-PC	Installing Autodesk Licensing: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\x86\AdskLicensing\AdskLicensing-installer.exe" --mode unattended --unattendedmodeui none
2019/4/24:17:31:54	Pats	PATS-PC	Autodesk Licensing return code: 0
2019/4/24:17:31:54	Pats	PATS-PC	Install	Autodesk Licensing	Succeeded
2019/4/24:17:31:54	Pats	PATS-PC	Installing Autodesk Single Sign-On:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2020" SETUP_PACKAGECODE={16CE94D7-2400-4633-84E0-274E7AC9C466} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D6156F59-2F22-4AB0-A9C0-C2D2C6E9D1EA} ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:32:08	Pats	PATS-PC	Install	Autodesk Single Sign-On	Succeeded
2019/4/24:17:32:08	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="J:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:32:47	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:32:47	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="J:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:33:26	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:33:26	Pats	PATS-PC	Component: INVENTOR failed with code 16032019/4/24:17:33:26	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:33:26	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:33:27	Pats	PATS-PC	Download	Play	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:27	Pats	PATS-PC	Notify play	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:27	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1001(download started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:27	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1003(unpackage started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify status	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1009(download completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	readerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1011(unpackage completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	writerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Download	Complete	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	Notify complete	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:33:28	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe" is signed.
2019/4/24:17:33:28	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe	Succeeded
2019/4/24:17:33:28	Pats	PATS-PC	Extracting files from  solution stub
2019/4/24:17:33:28	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:33:28	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AIEED9.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:33:28	Pats	PATS-PC	AnalyzeInstallFailure() for log file: C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:33:28	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorontext returned: Error Context CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (08:D8) [17:33:25:988]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (08:D8) [17:33:25:988]: Machine policy value 'DisableRollback' is 0
MSI (s) (08:D8) [17:33:25:988]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 17:33:25: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Return value 3.
MSI (s) (08:D8) [17:33:25:992]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (08:D8) [17:33:25:998]: No System Restore sequence number for this installation.
MSI (s) (08:D8) [17:33:25:998]: Unlocking Server
2019/4/24:17:33:28	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorContext returned: Error String fatal error
2019/4/24:17:33:28	Pats	PATS-PC	AnalyzeInstallFailure() QueryAknURL returned: AKN Article https://knowledge.autodesk.com/search?p=INVPROSA&search=fatal error&sort=score&page=1&v=2020
2019/4/24:17:33:28	Pats	PATS-PC	AnalyzeInstallFailure() error 28672 mapping not found in error.xml
2019/4/24:17:33:32	Pats	PATS-PC	Rollback	Autodesk Single Sign-On	Succeeded
2019/4/24:17:33:32	Pats	PATS-PC	Rollback: Autodesk Licensing 	 component is exe :Ignored Rollback.
2019/4/24:17:33:32	Pats	PATS-PC	Rollback: Universal C Runtime (KB3118401) 	 component is exe :Ignored Rollback.
2019/4/24:17:33:32	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x64) 	 component is exe :Ignored Rollback.
2019/4/24:17:33:32	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x86) 	 component is exe :Ignored Rollback.
2019/4/24:17:33:36	Pats	PATS-PC	PageOpen	InstallCompleteDialog
2019/4/24:17:37:26	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:37:29	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:37:29	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:37:29	Pats	PATS-PC	Current Directory I:\Inventor_Pro_2020_English_Win_64bit_dlm
2019/4/24:17:37:29	Pats	PATS-PC	Launch
2019/4/24:17:37:29	Pats	PATS-PC	CommandLine
2019/4/24:17:37:29	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp
2019/4/24:17:37:32	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:37:30	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:37:30	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:37:30	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp
2019/4/24:17:37:30	Pats	PATS-PC	Launch
2019/4/24:17:37:32	Pats	PATS-PC	PageOpen	LaunchDialog
2019/4/24:17:37:34	Pats	PATS-PC	PageOpen	LicenseDialog
2019/4/24:17:37:52	Pats	PATS-PC	PageOpen	ProductInfoDialog
2019/4/24:17:37:52	Pats	PATS-PC	PageOpen	InventorFlavorSelectionDialog
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==DefaultLanguage:	en-us
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==InstallName:	INVENTOR
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ProductName:	Autodesk Inventor 2020
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==DisplayName:	Autodesk® Inventor® 2020
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==DeploymentName:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SetupTitle:	Autodesk Inventor 2020
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ConfigTransform:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ExeParams:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ProductCode:	{7F4DD591-2464-0001-0000-7107D70F3DB4}
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SupportLink:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==InfotainmentLink:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==MsiFileName:	inventor.msi
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==AdminImageConfigName:	Imgx64
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==AdminImageRoot:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==GetBaseDeploymentName:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==DeploymentLocation:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==DocumentLink:	https://www.autodesk.com/inventor-install-2020-enu
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==InstallDeploymentShortcut:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ModifyDeploymentShortcut:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SetupLockType:	2
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SetupNetworkType: 	0
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SystemLocale:	1045
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==EvalMsiFilePath:	C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp\SetupRes\eval.msi
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==EulaPath:	C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp\EULA
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==InstallLogPath:	C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==ConfigFile:	C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp\Setup.ini
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SetupPath:	C:\Users\Pats\AppData\Local\Temp\_AIA0F6.tmp\
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==NetworkLogPath:
2019/4/24:17:37:52	Pats	PATS-PC	Inventorui==SourceRoot:	I:\Inventor_Pro_2020_English_Win_64bit_dlm\
2019/4/24:17:37:55	Pats	PATS-PC	Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVNTOR
2019/4/24:17:37:55	Pats	PATS-PC	PageOpen	ProductSelectionDialog2
2019/4/24:17:37:58	Pats	PATS-PC	PageOpen	FullProgressDialog
2019/4/24:17:37:59	Pats	PATS-PC	SetupUiUtil::IsDriveSSD: path is C:\Program Files\Autodesk\
2019/4/24:17:37:59	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2019/4/24:17:38:10	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2019/4/24:17:38:10	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86) Update 4	Succeeded
2019/4/24:17:38:10	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2019/4/24:17:38:23	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2019/4/24:17:38:23	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64) Update 4	Succeeded
2019/4/24:17:38:24	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2013.log
2019/4/24:17:38:38	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2019/4/24:17:38:38	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2019/4/24:17:38:39	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2013.log
2019/4/24:17:38:54	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2019/4/24:17:38:54	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2019/4/24:17:38:54	Pats	PATS-PC	Installing Universal C Runtime (KB3118401): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2019/4/24:17:38:54	Pats	PATS-PC	Universal C Runtime (KB3118401) return code: 0
2019/4/24:17:38:54	Pats	PATS-PC	Install	Universal C Runtime (KB3118401)	Succeeded
2019/4/24:17:38:55	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2017\vc_redist.x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2017.log
2019/4/24:17:39:09	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x86) return code: 0
2019/4/24:17:39:09	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x86)	Failed	Failure is ignored, Result=1602
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2017 Redistributable (x86) 	 component is exe :Ignored Rollback.
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Universal C Runtime (KB3118401) 	 component is exe :Ignored Rollback.
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x64) 	 component is exe :Ignored Rollback.
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x86) 	 component is exe :Ignored Rollback.
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2012 Redistributable (x64) Update 4 	 component is exe :Ignored Rollback.
2019/4/24:17:39:09	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2012 Redistributable (x86) Update 4 	 component is exe :Ignored Rollback.
2019/4/24:17:39:10	Pats	PATS-PC	PageOpen	InstallCompleteDialog
2019/4/24:17:39:15	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:41:15	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:41:15	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:41:15	Pats	PATS-PC	Current Directory I:\Inventor_Pro_2020_English_Win_64bit_dlm
2019/4/24:17:41:15	Pats	PATS-PC	Launch
2019/4/24:17:41:15	Pats	PATS-PC	CommandLine
2019/4/24:17:41:15	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp
2019/4/24:17:41:21	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:41:18	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:41:18	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:41:18	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp
2019/4/24:17:41:18	Pats	PATS-PC	Launch
2019/4/24:17:41:21	Pats	PATS-PC	PageOpen	LaunchDialog
2019/4/24:17:41:25	Pats	PATS-PC	PageOpen	LicenseDialog
2019/4/24:17:41:28	Pats	PATS-PC	PageOpen	ProductInfoDialog
2019/4/24:17:41:28	Pats	PATS-PC	PageOpen	InventorFlavorSelectionDialog
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==DefaultLanguage:	en-us
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==InstallName:	INVENTOR
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ProductName:	Autodesk Inventor 2020
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==DisplayName:	Autodesk® Inventor® 2020
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==DeploymentName:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SetupTitle:	Autodesk Inventor 2020
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ConfigTransform:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ExeParams:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ProductCode:	{7F4DD591-2464-0001-0000-7107D70F3DB4}
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SupportLink:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==InfotainmentLink:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==MsiFileName:	inventor.msi
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==AdminImageConfigName:	Imgx64
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==AdminImageRoot:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==GetBaseDeploymentName:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==DeploymentLocation:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==DocumentLink:	https://www.autodesk.com/inventor-install-2020-enu
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==InstallDeploymentShortcut:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ModifyDeploymentShortcut:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SetupLockType:	2
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SetupNetworkType: 	0
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SystemLocale:	1045
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==EvalMsiFilePath:	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\SetupRes\eval.msi
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==EulaPath:	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\EULA
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==InstallLogPath:	C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==ConfigFile:	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\Setup.ini
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SetupPath:	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==NetworkLogPath:
2019/4/24:17:41:28	Pats	PATS-PC	Inventorui==SourceRoot:	I:\Inventor_Pro_2020_English_Win_64bit_dlm\
2019/4/24:17:41:32	Pats	PATS-PC	Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2019/4/24:17:41:32	Pats	PATS-PC	PageOpen	ProductSelectionDialog2
2019/4/24:17:41:34	Pats	PATS-PC	PageOpen	FullProgressDialog
2019/4/24:17:41:34	Pats	PATS-PC	SetupUiUtil::IsDriveSSD: path is C:\Program Files\Autodesk\
2019/4/24:17:41:35	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2019/4/24:17:41:50	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2019/4/24:17:41:50	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86) Update 4	Succeeded
2019/4/24:17:41:50	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2019/4/24:17:42:01	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2019/4/24:17:42:01	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64) Update 4	Succeeded
2019/4/24:17:42:01	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2013.log
2019/4/24:17:42:10	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2019/4/24:17:42:10	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2019/4/24:17:42:10	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2013.log
2019/4/24:17:42:19	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2019/4/24:17:42:19	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2019/4/24:17:42:19	Pats	PATS-PC	Installing Universal C Runtime (KB3118401): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2019/4/24:17:42:19	Pats	PATS-PC	Universal C Runtime (KB3118401) return code: 0
2019/4/24:17:42:19	Pats	PATS-PC	Install	Universal C Runtime (KB3118401)	Succeeded
2019/4/24:17:42:20	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2017\vc_redist.x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2017.log
2019/4/24:17:42:28	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x86) return code: 0
2019/4/24:17:42:28	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x86)	Succeeded
2019/4/24:17:42:28	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2017\vc_redist.x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2017.log
2019/4/24:17:42:38	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x64) return code: 0
2019/4/24:17:42:38	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x64)	Succeeded
2019/4/24:17:42:38	Pats	PATS-PC	Installing Autodesk Licensing: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\x86\AdskLicensing\AdskLicensing-installer.exe" --mode unattended --unattendedmodeui none
2019/4/24:17:42:40	Pats	PATS-PC	Autodesk Licensing return code: 0
2019/4/24:17:42:40	Pats	PATS-PC	Install	Autodesk Licensing	Succeeded
2019/4/24:17:42:40	Pats	PATS-PC	Installing Autodesk Single Sign-On:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2020" SETUP_PACKAGECODE={16CE94D7-2400-4633-84E0-274E7AC9C466} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D6156F59-2F22-4AB0-A9C0-C2D2C6E9D1EA} ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:42:49	Pats	PATS-PC	Install	Autodesk Single Sign-On	Succeeded
2019/4/24:17:42:49	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:44:54	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:44:55	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:45:18	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:45:18	Pats	PATS-PC	Component: INVENTOR failed with code 16032019/4/24:17:45:18	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:45:18	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:45:19	Pats	PATS-PC	Download	Play	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:19	Pats	PATS-PC	Notify play	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:19	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1001(download started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:19	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1003(unpackage started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify status	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1009(download completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	readerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1011(unpackage completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	writerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Download	Complete	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	Notify complete	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:45:20	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe" is signed.
2019/4/24:17:45:20	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe	Succeeded
2019/4/24:17:45:20	Pats	PATS-PC	Extracting files from  solution stub
2019/4/24:17:45:20	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:45:20	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AI9395.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:45:20	Pats	PATS-PC	AnalyzeInstallFailure() for log file: C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:45:20	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorontext returned: Error Context CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (74:D0) [17:45:18:653]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (74:D0) [17:45:18:653]: Machine policy value 'DisableRollback' is 0
MSI (s) (74:D0) [17:45:18:653]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 17:45:18: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Return value 3.
MSI (s) (74:D0) [17:45:18:654]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (74:D0) [17:45:18:655]: No System Restore sequence number for this installation.
MSI (s) (74:D0) [17:45:18:655]: Unlocking Server
2019/4/24:17:45:20	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorContext returned: Error String fatal error
2019/4/24:17:45:20	Pats	PATS-PC	AnalyzeInstallFailure() QueryAknURL returned: AKN Article https://knowledge.autodesk.com/search?p=INVPROSA&search=fatal error&sort=score&page=1&v=2020
2019/4/24:17:45:20	Pats	PATS-PC	AnalyzeInstallFailure() error 28672 mapping not found in error.xml
2019/4/24:17:45:23	Pats	PATS-PC	Rollback	Autodesk Single Sign-On	Succeeded
2019/4/24:17:45:23	Pats	PATS-PC	Rollback: Autodesk Licensing 	 component is exe :Ignored Rollback.
2019/4/24:17:45:23	Pats	PATS-PC	Rollback: Universal C Runtime (KB3118401) 	 component is exe :Ignored Rollback.
2019/4/24:17:45:23	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x64) 	 component is exe :Ignored Rollback.
2019/4/24:17:45:23	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x86) 	 component is exe :Ignored Rollback.
2019/4/24:17:45:24	Pats	PATS-PC	PageOpen	InstallCompleteDialog
2019/4/24:17:48:44	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:51:58	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:51:58	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:51:58	Pats	PATS-PC	Current Directory I:\Inventor_Pro_2020_English_Win_64bit_dlm
2019/4/24:17:51:58	Pats	PATS-PC	Launch
2019/4/24:17:51:58	Pats	PATS-PC	CommandLine
2019/4/24:17:51:58	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp
2019/4/24:17:52:00	Pats	PATS-PC	=== Setup ended ===
2019/4/24:17:51:59	Pats	PATS-PC	=== Setup started on PATS-PC by Pats ===
2019/4/24:17:51:59	Pats	PATS-PC	Path_Length: 111
2019/4/24:17:51:59	Pats	PATS-PC	Current Directory C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp
2019/4/24:17:51:59	Pats	PATS-PC	Launch
2019/4/24:17:52:00	Pats	PATS-PC	PageOpen	LaunchDialog
2019/4/24:17:52:02	Pats	PATS-PC	PageOpen	LicenseDialog
2019/4/24:17:52:04	Pats	PATS-PC	PageOpen	ProductInfoDialog
2019/4/24:17:52:04	Pats	PATS-PC	PageOpen	InventorFlavorSelectionDialog
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==DefaultLanguage:	en-us
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==InstallName:	INVENTOR
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ProductName:	Autodesk Inventor 2020
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==DisplayName:	Autodesk® Inventor® 2020
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==DeploymentName:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SetupTitle:	Autodesk Inventor 2020
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ConfigTransform:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ExeParams:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ProductCode:	{7F4DD591-2464-0001-0000-7107D70F3DB4}
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SupportLink:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==InfotainmentLink:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==MsiFileName:	inventor.msi
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==AdminImageConfigName:	Imgx64
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==AdminImageRoot:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==GetBaseDeploymentName:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==DeploymentLocation:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==DocumentLink:	https://www.autodesk.com/inventor-install-2020-enu
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==InstallDeploymentShortcut:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ModifyDeploymentShortcut:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SetupLockType:	2
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SetupNetworkType: 	0
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SystemLocale:	1045
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==EvalMsiFilePath:	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\SetupRes\eval.msi
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==EulaPath:	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\EULA
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==InstallLogPath:	C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==ConfigFile:	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\Setup.ini
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SetupPath:	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==NetworkLogPath:
2019/4/24:17:52:04	Pats	PATS-PC	Inventorui==SourceRoot:	I:\Inventor_Pro_2020_English_Win_64bit_dlm\
2019/4/24:17:52:05	Pats	PATS-PC	Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2019/4/24:17:52:05	Pats	PATS-PC	PageOpen	ProductSelectionDialog2
2019/4/24:17:52:07	Pats	PATS-PC	PageOpen	FullProgressDialog
2019/4/24:17:52:07	Pats	PATS-PC	SetupUiUtil::IsDriveSSD: path is C:\Program Files\Autodesk\
2019/4/24:17:52:08	Pats	PATS-PC	Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2010.log
2019/4/24:17:52:13	Pats	PATS-PC	Microsoft Visual C++ 2010 SP1 Redistributable (x64) return code: 0
2019/4/24:17:52:13	Pats	PATS-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x64)	Succeeded
2019/4/24:17:52:13	Pats	PATS-PC	Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2010.log
2019/4/24:17:52:17	Pats	PATS-PC	Microsoft Visual C++ 2010 SP1 Redistributable (x86) return code: 0
2019/4/24:17:52:17	Pats	PATS-PC	Install	Microsoft Visual C++ 2010 SP1 Redistributable (x86)	Succeeded
2019/4/24:17:52:18	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2019/4/24:17:52:28	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x86) Update 4 return code: 0
2019/4/24:17:52:28	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x86) Update 4	Succeeded
2019/4/24:17:52:28	Pats	PATS-PC	Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2019/4/24:17:52:38	Pats	PATS-PC	Microsoft Visual C++ 2012 Redistributable (x64) Update 4 return code: 0
2019/4/24:17:52:38	Pats	PATS-PC	Install	Microsoft Visual C++ 2012 Redistributable (x64) Update 4	Succeeded
2019/4/24:17:52:38	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2013.log
2019/4/24:17:52:47	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
2019/4/24:17:52:47	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x86)	Succeeded
2019/4/24:17:52:48	Pats	PATS-PC	Installing Microsoft Visual C++ 2013 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2013.log
2019/4/24:17:52:57	Pats	PATS-PC	Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
2019/4/24:17:52:57	Pats	PATS-PC	Install	Microsoft Visual C++ 2013 Redistributable (x64)	Succeeded
2019/4/24:17:52:58	Pats	PATS-PC	Installing Universal C Runtime (KB3118401): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2019/4/24:17:52:58	Pats	PATS-PC	Universal C Runtime (KB3118401) return code: 0
2019/4/24:17:52:58	Pats	PATS-PC	Install	Universal C Runtime (KB3118401)	Succeeded
2019/4/24:17:52:59	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x86): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2017\vc_redist.x86.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x86_2017.log
2019/4/24:17:53:08	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x86) return code: 0
2019/4/24:17:53:08	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x86)	Succeeded
2019/4/24:17:53:08	Pats	PATS-PC	Installing Microsoft Visual C++ 2017 Redistributable (x64): "I:\Inventor_Pro_2020_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2017\vc_redist.x64.exe" /install /quiet /norestart /log C:\Users\Pats\AppData\Local\Temp\vcredist_x64_2017.log
2019/4/24:17:53:18	Pats	PATS-PC	Microsoft Visual C++ 2017 Redistributable (x64) return code: 0
2019/4/24:17:53:18	Pats	PATS-PC	Install	Microsoft Visual C++ 2017 Redistributable (x64)	Succeeded
2019/4/24:17:53:18	Pats	PATS-PC	Installing Autodesk Licensing: "I:\Inventor_Pro_2020_English_Win_64bit_dlm\x86\AdskLicensing\AdskLicensing-installer.exe" --mode unattended --unattendedmodeui none
2019/4/24:17:53:20	Pats	PATS-PC	Autodesk Licensing return code: 0
2019/4/24:17:53:20	Pats	PATS-PC	Install	Autodesk Licensing	Succeeded
2019/4/24:17:53:20	Pats	PATS-PC	Installing Autodesk Single Sign-On:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Inventor 2020" SETUP_PACKAGECODE={16CE94D7-2400-4633-84E0-274E7AC9C466} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={D6156F59-2F22-4AB0-A9C0-C2D2C6E9D1EA} ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:53:26	Pats	PATS-PC	Install	Autodesk Single Sign-On	Succeeded
2019/4/24:17:53:27	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:53:50	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:53:51	Pats	PATS-PC	Installing Autodesk® Inventor® 2020:  TRANSFORMS="I:\Inventor_Pro_2020_English_Win_64bit_dlm\x64\en-us\INV\inventor.mst;C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\x64\INV\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Inventor_Pro_2020_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2020\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2019/4/24:17:54:14	Pats	PATS-PC	Install	Autodesk® Inventor® 2020	Failed	Installation aborted, Result=1603
2019/4/24:17:54:14	Pats	PATS-PC	Component: INVENTOR failed with code 16032019/4/24:17:54:15	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:54:15	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:54:16	Pats	PATS-PC	Download	Play	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:16	Pats	PATS-PC	Notify play	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:16	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1001(download started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:16	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1003(unpackage started)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify status	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1009(download completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	readerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	1011(unpackage completed)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify info	SOLUTION_PROVIDER_PACKAGE	writerStreamThread exited with status code: (0)	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Download	Complete	SOLUTION_PROVIDER_PACKAGE	https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	Notify complete	SOLUTION_PROVIDER_PACKAGE		https://emsfs.autodesk.com/utility/SolutionFramework/FY19/SolutionProvider.exe
2019/4/24:17:54:17	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe" is signed.
2019/4/24:17:54:17	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\adsksolutionstub\SolutionProvider.exe	Succeeded
2019/4/24:17:54:17	Pats	PATS-PC	Extracting files from  solution stub
2019/4/24:17:54:17	Pats	PATS-PC	verifyCertificates	The file "C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\Setup\SolutionProvider.dll" is signed.
2019/4/24:17:54:17	Pats	PATS-PC	CertFindCertificateInStore	C:\Users\Pats\AppData\Local\Temp\_AI63D9.tmp\Setup\SolutionProvider.dll	Succeeded
2019/4/24:17:54:17	Pats	PATS-PC	AnalyzeInstallFailure() for log file: C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log
2019/4/24:17:54:17	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorontext returned: Error Context CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (34:10) [17:54:14:735]: Note: 1: 2265 2:  3: -2147287035
MSI (s) (34:10) [17:54:14:736]: Machine policy value 'DisableRollback' is 0
MSI (s) (34:10) [17:54:14:736]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 17:54:14: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Return value 3.
MSI (s) (34:10) [17:54:14:737]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (34:10) [17:54:14:738]: No System Restore sequence number for this installation.
MSI (s) (34:10) [17:54:14:738]: Unlocking Server
2019/4/24:17:54:17	Pats	PATS-PC	AnalyzeInstallFailure() GetErrorContext returned: Error String fatal error
2019/4/24:17:54:17	Pats	PATS-PC	AnalyzeInstallFailure() QueryAknURL returned: AKN Article https://knowledge.autodesk.com/search?p=INVPROSA&search=fatal error&sort=score&page=1&v=2020
2019/4/24:17:54:17	Pats	PATS-PC	AnalyzeInstallFailure() error 28672 mapping not found in error.xml
2019/4/24:17:54:20	Pats	PATS-PC	Rollback	Autodesk Single Sign-On	Succeeded
2019/4/24:17:54:20	Pats	PATS-PC	Rollback: Autodesk Licensing 	 component is exe :Ignored Rollback.
2019/4/24:17:54:20	Pats	PATS-PC	Rollback: Universal C Runtime (KB3118401) 	 component is exe :Ignored Rollback.
2019/4/24:17:54:20	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x64) 	 component is exe :Ignored Rollback.
2019/4/24:17:54:20	Pats	PATS-PC	Rollback: Microsoft Visual C++ 2013 Redistributable (x86) 	 component is exe :Ignored Rollback.
Replies (35)
Message 2 of 36
harpole
I had the exact same thing happen to me yesterday, and am still without a solution. I'm glad I'm not the only one, I thought it was something I did. I'm speaking with autodesk and will let you know if I get a solution.
Message 3 of 36
patrykstolinski
Oh no...I have some very important college work to do till the end of the week. I was really ,really hoping it was something I did that had a fix...if not, then I'm basically in the butt. Please do tell if you find anything about the predicament.
Message 4 of 36
harpole
To add to the frustration, I ended up even restoring Windows to an earlier date when the software previously worked, and it still would not correct the issue. Strange.
Message 5 of 36
DannyHubbard
Can you post the more detailed install log "C:\Users\Pats\AppData\Local\Temp\Inventor2020Install.log"
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 6 of 36
harpole
Hi Danny,
Yes here it is.
Message 7 of 36
Hello @DannyHubbard ,
Of course, here it is.
@harpole Glad you wrote it, I was about to scrape and reinstall the system clean..
Message 8 of 36
Mark.Lancaster
I'm seeing 1603 error on installing the core Inventor product which isn't good..   I would start here https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-1603-during-instal...
Mark Lancaster
Message 9 of 36
harpole
I already followed those instructions. They do not resolve the problem.
Message 10 of 36
patrykstolinski
Hello @Mark.Lancaster
Thank you for the reply - I have followed all the instructions:
  • Cleaned up all residue from autodesk installations and programs alike, including deleting all functioning programs like Fusion
  • cleared out the TEMP folder
  • Have more than double free disk space
  • Checked registry for file creation, set to 0
I have also deleted previous C++ installations as suggested in other guides for error 1603, I have tried installing it on other HDD drives, on SSD drive, relogging, redownloading the files, rebooting the system.
Message 11 of 36
Mark.Lancaster
@patrykstolinski
I notice you are installing from the "I" drive.  Is that a network drive, portable hard drive?
Mark Lancaster
Message 12 of 36
patrykstolinski
It is not, it's an SSD drive installed into my case.
Message 13 of 36
DannyHubbard
In both cases it appears the install if failing because of the existing Autodesk Licensing service.
Try uninstalling it by running the Uninstall.exe at C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing
Once the uninstall is complete delete this AdskLicensing folder and try installing Inventor again.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 14 of 36
harpole
Thanks Danny,
This resolved the problem!
Danny
I was able to reinstall Inventor 2020 following this method.
Message 15 of 36
patrykstolinski
Hey, can you perhaps share what kind of installation you used? Webinstall, downloaded through manager, through browser? Did you perform a clean install, deleted your C++ libraries beforehand?
Also, when you clicked uninstall on the licensing, did it pop any wizard or do nothing and just 'deleted' the contents of the folder?
Message 16 of 36
harpole
Once I ran the uninstall.exe, I believe it popped up a dialog box to run the uninstaller. Then the contents deleted without any acknowledgement. After the files deleted, I then removed the Folder as mentioned, and then ran the Browser Download from the Autodesk website.
Message 17 of 36
harpole
I forgot to mention I did also delete the C++ libraries beforehand. I also performed a clean install. I removed all of the Autodesk Software and files. I am not sure if this is required or not to resolve the problem as I did it earlier when i was trying to find a solution to the issue.
Message 18 of 36
patrykstolinski
When I run uninstall from the Adsklicensing, it prompts no window and just deletes the files. While that's nothing bad, when installing Inventor 2020 it throws an error prompt saying "unable to start adsklicensingservice". The error 1603 persists and I have no clue what I'm doing wrong, since it helped another person here.
I have attached adsklicensing install log, it throws a bunch of errors...
Message 19 of 36
harpole
Here are the steps I followed that worked for me:
1. Removed all autodesk products and folders. (Use the Autodesk Uninstall tool found under programs/ Autodesk)
https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
2. Uninstall all C++
3. Delete License Folder as described by Danny
4. Changed regedit value to 0 for short naming enable
5. Downloaded Inventor from Browser (note that you need to allow Pop-Ups in your browser). There should be 3 inventor files that are downloaded. When Downloaded, select one of them to install the product.
Message 20 of 36
patrykstolinski
Ah so you also deleted the Autodesk shared folder, as in the link you gave? I will delete everything there and try that way again, thank you.
