Inventor sketch block will not delete
william
Message 1 of 28
william
Hello
I have a part file that keeps giving errors on new features, basic extrudes, etc. After digging into it, it appears to be a single sketch block & associated parameters that are the problem.
I have tried every way i can think of to delete the parameters and the sketch block, it it refuses to be deleted.
I have stripped the part right back to only containing the sketch block, no other parameters, sketches, or features and it still will not delete.
I really dont want to create a new part and spend 3-4hrs rebuilding the part from scratch because of 1 sketch block.
Can anyone figure this out?
Replies (27)
Message 21 of 28
kimK7B54
@kimK7B54 wrote:  (reply to add missing images)
That does not work.
This is the only dimension it brings in, and it is not a needed dimension.
I need to be able to "auto-populate" some these variables.  This would
change a 2 hour job into a 5 minute job.
Currently I have to manually find these ( in a list of up to 50
iFeatures, locate the correct one, and insert the value )
I have to go to the model to identify which iFeature I am detailing,
then back to the idw;  Very, very time consuming.
Message 22 of 28
johnsonshiue
Hi! It seems like a bug or a limitation in the iFeature. I suggest you start a new thread with the iFeature ide file and the source ipt file extracting the iFeature. I would like to understand why the iFeature parameters are not being retrieved in the drawing.
Many thanks!
Software Test Engineer
Message 23 of 28
aperrone_lc
I didn't have much luck with @bradeneuropeArthur 's solution, but I figured out why. My offending "phantom sketch" wasn't at index 1. I used the following modification of Arthur's code to figure out the index I needed to kill:
Dim a As PartDocument = ThisDoc.Document
MsgBox(a.ComponentDefinition.Sketches.Count)
For i = 1 To a.ComponentDefinition.Sketches.Count:
	MsgBox(a.ComponentDefinition.Sketches.Item(i).Name)
Next
a.ComponentDefinition.Sketches.Item(2).Delete
Note that I ran this once, then modified line 9 to delete the correct index. There doesn't seem to be any harm in getting the index wrong on the first run-through; it'll just throw an error. Also, this will get annoying on a large model. Mine only had 3 or 4 sketches, so it was quick to run through the repeating message boxes. There is surely a more elegant solution to be had.
Message 24 of 28
RobNZIFSL
I have a master part containing around thirty blocks, perhaps half of those nested.  Copying out the required blocks (all but the two I want to delete) is not a viable solution due to derived components dependency on the master part.
I want to delete the two blocks shown below.  You can see one is nested into the other.  I have edited the 'parent' to window select all content and then deleted that content; this has not removed the 'child' block.  I have also run the above code without improvement.
I believe it could be resolved by removing the implied parent child reference but don't know how to do this.  Any thoughts?
Message 25 of 28
johnsonshiue
Hi Rob,
This could be a corruption. Somehow the sketch block is still referenced by a ghosted sketch. Please share the file here or send it to me directly johnson.shiue@autodesk.com. I can take a look to see if it is indeed a corruption and it can be purged.
Many thanks!
Message 26 of 28
msonderegger
I have a similar situation...a certain block will not delete.  It appears to be causing a bunch of style library XML issues in 2025 which we just "migrated" to.  Of course, this ancient file with this block error spawned most of our graphics & label files over the years, so the error prone block is spread throughout several files at this point.  I have deleted everything from within the block...no change, and still can't delete it. Even once I delete everything in the part, I still can't delete this one block.
ILOGIC CODE:
I did successfully use that ilogic code, but it only worked after I deleted everything I could from my file.  On a positive note, sure enough after running that code, I was then able to delete the block.  However, I feel like I have just created a "new file", since its completely empty?  Was this the intent?  I'm unclear how this is useful?  Maybe the hope is to copy everything back into that file with a little copy-paste magic (and hours of frustration and direction guessing in the absence of a graphical illustration of previous references like other CAD SW had decades ago)?  Anyhow, in my case, the first feature in these parts is typically a DERIVE, so I have no means to go grab a copy of the problem file and copy everything over - DERIVES don't seem to copy & paste AFAIK.  So, FILE-NEW, recreate everything, and replace the bad files everywhere with the new ones is certainly an option I was aware of long before reading this thread...but...I guess I was hoping for more.  Anyone with insights?  What am I missing?
Message 27 of 28
bradeneuropeArthur
Could you share a file without cleaning up?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 28 of 28
cornel.paraschiv.external
Observer
Observer
Worked for me !
