Inventor Shape Generator
khkon
khkon
i can't use the shape generator. I use Inv 2016 pro with a subscription. But the butten is alway hide.
Any idea how i can activate that butten?
regards
Klaus Haßler
JDMather
Are you in an active part file or are you in an assembly?
(not editing a part in the context of assembly)
jalger
Hi Khkon,
The shape generator tool is not available in the assembly environment.
You would have to open the part up by itself to use it.
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-D74F47F3-FE22-44EF-85BE-7C6B1F56DCF9
Note: Shape Generator is not supported for assemblies or multi-body parts (single parts which contain multiple bodies).
From your picture I can see that you are trying to edit a part while in the assembly.
( in 2016 it doesn't work like that, not sure if its fixed in the 2017 release)
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
khkon
Thank you for the help!
