Inventor Forum
Inventor Section 3d drawing into multiple 3d prints
4 REPLIES 4
443 Views, 4 Replies
I'm trying to 3d print an ABS mold of an 80" long by 6 inch high object.  I can't figure out how to section my model into the multiple 6" sections, though I know I'll need 14 roughly the same size sections.  Any help or point in the right direction would be very much appreciated.
4 REPLIES 4
blair
I assume that you modeled it as a single IPT and didn't use any multi-body modeling techniques. I would Derive from the base model and cut to get each section to get the 14 pieces that you will need. You might be able to get away with possibly using some center pieces a number of times if they are the same
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
In addition to blairs suggestion of split derived components - when I have large parts to 3d print I also add locating pins and holes to help when glueing them together.  Just keep in mind that the printer isn't perfect - allow for tolerance on the holes/pins.
in reply to: JDMather
JDMather, I'm sure you're asked this all the time, but can I hire you by the hour to teach me about 20 concepts I can think of related to your post? I'm seanreit at gmail
Sean
blair
As JD posted, I would if possible go with "Through-Holes" and use some treaded Tie-Rods to align and hold it together. Possible for-planning might allow you to make an adjustable modular mold for different lengths or the addition of different options.
Delta Tau Chi ΔΤΧ
