Inventor Forum
Inventor Rename Main Assembly With Design Assistant
8 REPLIES 8
Message 1 of 9
toznal
3110 Views, 8 Replies
Hi, there.
How to rename main assembly?
I use Design Assistant, It can be rename only part or sub assemblies.
Is there way to rename main assembly file?
Thank you.
kelly.young has edited your subject line for clarity: RENAME MAIN ASSEMBLY IN INVNETOR
8 REPLIES 8
Message 2 of 9
admaiora
in reply to: toznal
Right click on file>rename
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 9
toznal
in reply to: admaiora
It grey out....
just can rename included sub assembly and part.
Could you mind show me how to do this on your computer?
Message 4 of 9
admaiora
in reply to: toznal
Let me see, maybe I have not understand correctly.
You have the main assembly "Machine-1.iam".
Then sub parts and sub assemblies in it ( "bracket-1.ipt", "motor-1.iam", etc etc).
If you want to rename sub parts and sub assemblies you have to use design assistant, Vault, iLogic Copy Design, etc.
You want to rename "Machine-1.iam" and change it in "Machine-2018.iam"
Correctly?
Just close all your files.
Find in your Windows folder "Machine-1.iam"  and just simply rename it, as a normal files.
Only that assembly should not be already included in another assembly, just be the main assembly.
You can create  a duplicate of "Machine-1.iam" just saving as another name too, or save copy as.
Admaiora
Message 5 of 9
toznal
Thank you for response.
I'm sorry, I'm not English native.
=> Do you mean what file renames like normal pptx, excel files?
=> Do I have to save copy as?
I just want to change name..not copy... I have to rename to another name.
Message 6 of 9
mcgyvr
in reply to: toznal
File.. Save As
I'm not sure though what you are really trying to rename.. Simply saving it as a new file will obviously change the file name though if that is what you are asking..
Message 7 of 9
gcooper79
in reply to: toznal
Hi Toznal,
As has previously been suggested, if the assembly is a top level assembly and has not been referenced in a drawing, you can simply rename the assembly in windows explorer.  If the assembly is referenced in a drawing, navigate to the drawing file using design assistant and you should be able to rename the assembly from there.
regards,
Graeme
Graeme
Message 8 of 9
johnsonshiue
in reply to: gcooper79
Or, you can save copy as a different iam file. Then replace any reference with the newly saved iam file.
Many thanks!
Software Test Engineer
Message 9 of 9
kelly.young
in reply to: toznal
Hello @toznal to clarify what @admaiora has stated, you can do this outside of Inventor with all the files closed. Find your top level assembly file within Explorer and change the name there.
If you want to do it with Inventor open, you'll have to do a SaveAs to a new file with a new name you want, then go find the original file and delete it.
If you want to rename sub-assemblies without Design Assistant or other tool, you'll have to do SaveAs then RMB > Component > Replace with the newly named assembly.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
