Please tell me how to change from read only to read and write see jpg attached
Solved by todd_cannon. Go to Solution.
That tells me 2 things..
1. You have Inventor files opened in Inventor.
2. Somehow the file attributes outside of Inventor has it set to read only.
Mark Lancaster
& Autodesk Services MarketPlace Provider
As Mark said, make sure you don't have any files open. But, also make sure no one else has a file open that is using the project file you are trying to edit. I usually have to ask all others in my project to close out Inventor. That usually clears the read-only setting of the project file. Hope this helps.
Cheers,
Todd
