Inventor Professional fails to install on Windows 10, please help!
I am a student, and I am trying to download inventor. Every time i do though, it fails to install. I have attached the installation log file
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
TheCADWhisperer
Get these three files from the Autodesk Virtual Agent.
Mark.Lancaster
@Anonymous
Welcome to the community..
First remove Autodesk Design Review 2013 from Windows/Control Panel/Add&Remove Programs.  Its failing on Design Review because you probably have updates applied to it and the installer doesn't like it.  Then follow @TheCADWhisperer information or
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
I got this problem with other software of autodesk and i needed to format my pc
Hi Mark, I have the USB media, I was using this on windows 7 and all fine.,, now bought a new laptop and I am trying to install.,, installing in fine but when I try to open I get error 0xc0000142 and this is only for inventor.,, CAD works fine, please advice
mdavis22569
@Anonymous
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/The-application-was-unable-to-start-correctly-0xc0000142.html
Check this out
also are you able to use the download vs the USB?
Mike Davis
