Inventor pro wont open
Message 1 of 12
I finished installing inventor 2017 pro but every time i try to launch it it pops up for one second then disappears. I got an error once saying it needs to activate it but I cant open it to enter my serial number.
Replies (11)
Message 2 of 12
Mark.Lancaster
@Anonymous
Perform a license reset per this article.
Right mouse click on the Inventor desktop icon and select run as admin.
Mark Lancaster
Message 3 of 12
I cant find the files and I made sure to adjust my view settings.Capture.PNG
Message 4 of 12
Mark.Lancaster
@Anonymous
No problem..  It may be there and it might not as well.  It all depends on how far you get with the activation aspect of the software.
Did you run Inventor as a admin (like I indicated)?  If not try that and report back.
Mark Lancaster
Message 5 of 12
I tried to run it as an administrator but i still get the same result
Message 6 of 12
Mark.Lancaster
@Anonymous
What specs are your machine?  What graphics card/driver version do you have?
Mark Lancaster
Message 7 of 12
intel core Processor i7-7700K 4.20GHZ 8MB Intel Smart Cache LGA1151 (Kaby Lake)
16GB (8GBx2) DDR4/3000MHz Dual Channel Memory
250GB WD Blue M.2 SATA-III 6.0Gb/s SSD - 540MB/s Read and 465MB/s  Write
ASRock Z270 KILLER
Windows 10 Home (64-bit Edition)
gtx 1070
Message 8 of 12
blair
Try running the "register" utility and re-register Inventor:
Re-Register Inventor
1. open a command prompt as administrator
2. type :"C:\Program Files\Autodesk\Inventor 2017\Bin\Inventor.exe" /install
 3. Wait for about 30 seconds & then retry Inventor
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 9 of 12
how do i open a command prompt as administrator in windows 10
Message 10 of 12
blair
First you need to be logged in with Admin privileges, then RMB on the Start icon, you will then see the "Run" option, then type in CMD in the run box.
Delta Tau Chi ΔΤΧ
Message 11 of 12
It still only pops up for a second then doesnt open
Message 12 of 12
blair
Sounds like a bad install. I would use the Autodesk "Un-Install" program that should be in the Autodesk program file (Start>Programs>Autodesk>Un-Install).
Reboot your computer and make sure that you are logged in with Administrative privileges to install Inventor. Make sure that you are current on all Windows updates for your computer.
Delta Tau Chi ΔΤΧ
