Inventor Part Modeling of Fork Slot Cut Feature
Hello. I have a problem :(.
How do I make a gap there, as shown?
Thank you very much 🙂
kelly.young has edited your subject line for clarity: I need help with a fork
mcgyvr
Please attach your attempt at the ipt file and also include the version of Inventor you want..
In general though had you created your sketches constrained about the origin you simply needed to create a sketch on the origin plane and extrude (cut option).
Once you post your ipt file we can correct it and show you how it should be done..
Have you asked your teacher though for help? Surely they should be able to help you..
Thank you 🙂
Can I ask where send the IPT file?
TheCADWhisperer
Attach it here.
Here 🙂
TheCADWhisperer
Maybe something like this?  (see attached)
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Thanks for attaching your part for review. Using Extrude Cut is the easiest way with what you already have done.
Here is a screencast showing a few tips using the model you supplied.
Inspect the part attached by @TheCADWhisperer, it is the best way to go about it for simplicity.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
