Inventor Part List - Item Number column missing
GKPByDesign
GKPByDesign
Hey I cannot seem to show my item properties, I have looked into the group settings, ticked-and un-ticked, but I cannot seem to show the item numbers. My assembly is very large over 170 unique assemblies and 2000+ parts. Would that cause the issue? I need help!
rhasell
Hi
Can you supply a few screen captures/screen cast or an example?
It's difficult to visualize the problem.
Reg
2025.1.2
Please Accept as a solution / Kudos
Sergio.D.Suárez
Hi, share an image of the partslist so we can see it. I told you what I would do. Try to edit the partslist, then right clicking on some title of the column of the partslist select "column chooser"
, then select "ITEM", and then "Add".
Press OK, then Apply, then OK
You should verify that in your language of inventor the column is as appropriate. I hope you can solve it, greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
GKPByDesign
Hey, yea for some reason the ITEM prop disappeared from column chooser, so I made a new part list style based on the default template and brought that into my drawing, edited that inside the drawing and then was able to edit my custom style on the existing drawing as the item prop reappeared, very strange bug !
