I'm having issues with the inventor parameter table not updating. When running a rule, I call out another rule that updates a parameter, in this case d_TEST. I call out a msgbox that displays the value of this rule in the called out rule, then when it returns to the original rule, I want to run some code based upon the new d_TEST value, but it still reports the parameter as the original unchanged value.
I have tried including all of the following lines to try and "update" the parameters, application, and document, but to no avail. I have tried including this in the original rule, and the called out rule as well:
ThisDoc.Document.Rebuild() RuleParametersOutput() iLogicVb.UpdateWhenDone = True Parameter.UpdateAfterChange = True InventorVb.DocumentUpdate()
Attached is a sample part with a couple ilogic rules showing what I mean. This is a very simplified version of what I'm trying to do in another part/assembly.
hello Calaes
instead of using
d_TEST = 9 in
try using
Parameter("d_TEST") = 9
this will update the parameter earlier
use it in both testrules.
the first option will update the value at the end of the first rule
