Inventor opens files in a new window
marco_a
marco_a
I started tinkering with file association in Windows Explorer, and... I ended messing it up. 😬.
What I have now is:
  • .ipt and .iam files changed their icons (while .idw and .ipn files still have their correct icons, see pics);
  • if I open a file from Windows Explorer, it opens in a new Inventor window, instead of opening as a new tab in the main window as usual.
2022-08-29 10_12_31-__VX-MARCOA_Inventor_Pulsantiere Serie 4000_parti.png2022-08-29 10_13_18-__VX-MARCOA_Inventor_Pulsantiere Serie 4000_disegni.pngI tried to re-register the application as suggested here, without success.
I also tried uninstalling Inventor and reinstalling it, without success.
Is it possible to do something to restore the original behaviour?
Thank you!
Best regards,
Marco A.
-niels-
I vaguely remember something with running "DtDv.exe", but i can't find any good references for it.
It had to do with Inventor view at the time, same sort of problem with file association...
Make sure windows has properly associated the file type to Inventor and try running "DtDv.exe"....
Sorry if this is a bit of a useless post...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
marco_a
thank you very much for your quick reply!
Before trying it, I wanted to do as following:
  • change file association, from Inventor to a completely different applicazion (I chose Notepad);
  • revert file association, from Noteopad to Inventor.
I noticed that I have two "Autodesk Inventor® 2023" entries:
one of them gives the faulty behaviour, while the other one solved the problem!
I made this both for .iam and .ipt, and now everything seems to work properly.
Thank you for taking time to solve my problem!
Marco A.
