Inventor on Apple Mac M1 processor under Parallels
ny2la36
Observer Observer
Message 1 of 27
ny2la36
Observer
Observer
Does anyone have suggestions and / or success on how to run  Autodesk Inventor or Fusion360 on my Apple Macbook Pro M1 which is running Parallels 17 ARM with Windows ARM installed ? thanks
Replies (26)
Message 21 of 27
gobluejd
I tried this and still get the warning it is using Software Graphics.  Any other suggestion?
I am using Parallels 19.3.1 on. MAC STUDIO M2 MAX (Sonoma 14.4.1)
Message 22 of 27
ChrisMitchell01
After you've edited the file, if you start Inventor & go to App Options, Hardware are you able to change to Performance mode or is that grayed out?
If you open a part file & run the Inventor graphics diagnostics from the app options, hardware & copy/paste the info into a text file, do you see any errors or useful info? Can you attach your graphics diagnostic info & also your edited hardwarelibrary.xml file?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 23 of 27
gobluejd
I will do this first thing tomorrow am. Thanks for replying.
Message 24 of 27
gobluejd
See attached files.  After I edit the file, I open inventor and select a IPT file and get the attached screen shot.  I also attached the App options for Hardware.  Even if I deselect the SOFTWARE GRAPHICS check box and reopen, it is still checked.
Message 25 of 27
ChrisMitchell01
Does it work any better with the attached file instead ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 26 of 27
gobluejd
That worked! It did not bring the notification up.  When I go to Hardware now, it says Performance.
Whatever you did, thank you!
Message 27 of 27
gobluejd
Another question about this subject.  For some reason Inventor will not display proper fonts in Print Preview / Printing / PDF.  Just curious if anyone knows a solution.
