Hi
So am i reading this correctly?
You have a MacBook M1 running Windows 11 ARM (via Parallels i assume) and Inventor 2022 works?
Does it not crash every time you select 'File' ?
I tried the same setup with 2023 and it constantly crashed. I had managed to download 2023 via the 'Install Now' method and not the x3 file method.
Is your Windows version 11 10 ?
Tried downloading other versions of Inventor but only given the option of downloading via the x3 file method which simply did not work. It doesn't even indicate which of the files you 'execute'. Is it just the one or all three?
If you have a link to the exact point where you downloaded Inventor 2022 or can point me to the 'Install Now' download it would be appreciated; and your version of Windows 11
I'm starting to think buying the M1 was a big mistake, though in all other respects it is fine.
