- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've known for some time that making patterns for features is far more stable than making patterns within a sketch. I've finally come across a situation where I've got to create the pattern in the sketch. I need to make a cut with a polygonal shape that varies with size, number of sides, starting angle, and degree of tilt. As I'm using this as a template for use with automation, I also need to be able to rely on the part to self-manage and avoid the various tasks such as the wizards to go through and manually select all the edges to force a closed loop. Surely there's a process by now that'll accommodate such a need?
Can't pattern the "Cut Feature" because it only patterns the "result" and not the cutting tool.
Creating sketch patterns on floating planes & axis is far more effective if I can just get a closed loop.
@llorden4,
marius.gildehaus has edited your subject line for clarity
Original: Re: How to make a circular pattern be a closed loop?
