Inventor LT 2018 - Workspace
Luke.Hicks430
Message 1 of 8
Luke.Hicks430
I have a question on Inventor LT 2018:
Every time I save any Inventor LT document, it warns me that I am not saving it in the workspace.
This is pretty annoying. I know that with Inventor (non-LT) you can create a new project and set the project location, but I haven't found a way to do that in LT.
Is there a way to create projects in LT 2018? Can I change the workspace? Can I turn off they annoying warning?
Thank you all for your help!
- Inventor Noobie
Accepted solutions (3)
Replies (7)
Message 2 of 8
mcgyvr
I've never used LT but I thought that in tools..application options..file tab you can set the workpath..
Message 3 of 8
Luke.Hicks430
It is gray-ed out. See photo:
Message 4 of 8
Mark.Lancaster
@Luke.Hicks430
Not sure if you were able to change..  But when its disabled in application options it usually points to having files open in Inventor.  Just like full Inventor, changes to the project file are not permitted when files are opened in Inventor.
Mark Lancaster
Message 5 of 8
mdavis22569
isn't it:
Via?
Mike Davis
Message 6 of 8
Mark.Lancaster
@mdavis22569
That's the default location but I think the OP is not using that given location and that's why they are seeing the message..
Mark Lancaster
Message 7 of 8
mdavis22569
@Mark.Lancaster mentioned (as did I)
Change your location to where you're actually working
Close all files, so it's just the home screen, go into your application options ... and change it:
Mike Davis
Message 8 of 8
Luke.Hicks430
@mcgyvr@Mark.Lancaster@mdavis22569
Thank you,
You are all correct. I had a part open which is why I couldn't change it.
I appreciate the help!
