Like the title says, I would like a keyboard shortucut to apply constraints. I don't want to use my mouse. Does anyone have something? thanks a lot
P.S I don't want to use "Enter" I really want a custom key" Thanks
Solved by EdvinTailwind. Go to Solution.
Solved by johnsonshiue. Go to Solution.
I press C - and I don't think it's a custom command.
Or do you mean you want to set a specific constraint, like Flush, Mate or Concentric?
Hi! There isn't a dedicated key for Apply. I believe <Enter>, though assigned to Ok, behaves more like Apply.
Many thanks!
I just tested a little and noticed that as soon as you've selected the constraint references (two or three) you can just TAB once and Apply will be high-lighted and triggered if you press Enter.
Thanks Johnson for the info and thanks Edvin for the tip... If someone find a way to dedicate a key to apply, please tell me. Have a good day
