Inventor/Inventor Pro Install
I have an Inventor Pro 2014 install that only shows Inventor.
Is there one install for both and based on serial number you get the different product?
Or, is it in the deployment that the choice is made?
I forget....
Tim
JDMather
I can't remember back to 2014, but for at least the last couple of releases it is the Serial Number that determines the functionality.
There was only one set of install files (you can check the Autodesk Virtual Agent and see if there were different downloads for Inventor and Inventor Professional).
Also check your http://manage.autodesk.com
Mark.Lancaster
@Anonymous
No Inventor and Inventor Professional have different serial #s.   Are you sure you have Inventor Professional (and you just purchased Inventor).?  In addition they can't be installed on the same machine.
Mark Lancaster
I found the answer...
There is one install download and when developing the deployment, the product key selected changes it from Inventor or Inventor Pro.
Thanks....
