Inventor Forum
Inventor: Invalid axis/origin on a sketch
5 REPLIES 5
NigelHay
852 Views, 5 Replies
I have an error message about an invalid axis/origin in a part sketch. I understand that I need to select the X or Y axis & then pick a vertex to indicate the direction but how do I do this in a circular part with no appropriate vertexes to select?
Inv2019 pro.
5 REPLIES 5
jhackney1972
in reply to: NigelHay
I think the forum needs a bit more information from you to help with this issue.  Could you post your part and at lease give a screen capture.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
IgorMir
From a top of my head - I think you can redefine the axis by picking Part's Origin axis. Give it a try anyway.
Cheers,
Igor.
Inv2019 pro.
Web: www.meqc.com.au
NigelHay
in reply to: IgorMir
Sergio.Bertino
Thanks @NigelHay for letting us know that thanks to @IgorMir's help you found a way to solve your inquiry
Sergio Bertino
MFG Technical Support Specialist
IgorMir
You are welcome. 🙂
Technology Administrators
