Inventor: How to convert .skd / .skf files to .dwg / .ipt
Message 1 of 65
Hello guys!
Does anyone have a solution to situation that I am experiencing. We have legacy files in .SKD format.
How do we convert or open these sketch files and convert them to be used in Inventor/AutoCAD or any other workable formats in current times.
Thanks in advance.
@Anonymous,
marius.gildehaus has edited your subject line for clarity
Original: SKD FILES
Replies (64)
Message 2 of 65
marius.gildehaus
Hello @Anonymous!
I see that you are visiting as a new member to the Inventor Forum. Welcome to the Autodesk Community!
You need to have Autosketch to convert the data to .dwg files.
There is also an article about that:
How to open or convert AutoSketch files in AutoCAD
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Thanks!
Marius Gildehaus
Technical Sales Specialist
Message 3 of 65
HI!
Thanks for your response, but need a 64bit solution as most of the machines are 64. Or try unti I get hold of 32bit machine.
Message 4 of 65
marius.gildehaus
I think there is no 64 Bit option. That's why they are stating to use a virtual machine when you don't have 32 Bit system.
Hope this helps!
Marius Gildehaus
Message 5 of 65
j.palmeL29YX
.skd files are from the old AutoSketch 2/2.1. To open this files you need a newer AutoSketch (8 or 9 or 10, you can install it in a 64 bit environment too). Here you can open the old skd-files and save as dwg.
If you have only a handful files to convert, upload here and someone will do it for you.
cadder
Jürgen Palme
Message 6 of 65
@marius.gildehaus
I managed to run the converter on Virtual XP but the problem is that when I click save as only two options are available. See the attached screenshot.
Message 7 of 65
mcgyvr
@Anonymous wrote:
@marius.gildehaus
Is there an "export" button instead of save as maybe?
Or a "save copy as" vs "save as" button?
Message 8 of 65
Hi!
 @mcgyvr
This programme for conversion is a Limited Version where only save as is possible
Message 9 of 65
marius.gildehaus
Hello @Anonymous!
I think you misunderstood this article How to open old AutoSketch files in newer versions
This is just for converting old Autosketch data (2.0 and less) to 10 so you can save it with Autosketch to a DWG.
When you don't have Autosketch installed there will be no other option to convert this files, like it states in this article I wrote before: How to open or convert AutoSketch files in AutoCAD
"The drawing needs to be saved to DWG format from within AutoSketch"
Marius Gildehaus
Message 10 of 65
@marius.gildehaus
Thanks for your response, but I see that Autosketch is discontinued, any other Application that we can use?
Message 11 of 65
marius.gildehaus
In Google type in "autosketch download" and you will find something that will maybe work for you. But you will need a serial number for Autosketch.
From official side, we discontinued this product in 2008.
When you got this program running, please make sure to convert every legacy data you have to .dwg. That will make it easier for you in the future.
Hope this helps!
Marius Gildehaus
Message 13 of 65
j.palmeL29YX
How many files do we talk about here?
In a  german Forum  we have this question several times a year. And the users were helped every time ...
Can you  post one or two of your oldest files here to check first if they can be converted?
cadder
Jürgen Palme
Message 14 of 65
In 1998 I've builded a own house and designed the electricity schemes in a early version of AutoSketch.
In the mean time I need to modify those files as I'm making drastic changes to my home and need to have update schemes for our local building authorities.
I'm looking for a kind sole able/willing to convert 10 files SKF files (attached in ZIP) to a DWG format.
Are you or do you know who would be able to convert them?
Kind regards,
Gino
Message 15 of 65
j.palmeL29YX
Here it is.
cadder
Jürgen Palme
Message 16 of 65
I'm in a similar situation. I have autosketch files created in version 5. I still have my old distribution software CD for version 5. However, my 64-bit Windows 10 balks at installing it. Message says: "This app can't run on your PC." Can you give advice as to how to get it to run so that I can retrieve my drawing files and get them converted into something editible? Thanks.
Message 17 of 65
Hi Jürgen,
I also have a skd file that a customer has sent which we cannot open. Do you still have the ability to convert it to a dwg file?
Many thanks,
R
Message 18 of 65
johnsonshiue
Hi! I believe you might be able to find more information at Auto Sketch forum. Here is a simple query about skd files there.
https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
Many thanks!
Software Test Engineer
Message 19 of 65
j.palmeL29YX
Here you go ...
Jürgen Palme
Message 20 of 65
Thank you very much j.palmeL29YX "You may have just saved the day!"
I believe they have more files they need help converting. If that is the case they will contact you here.
Thanks again,
R
