Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Inventor How Do I Draw Cylinder With Groove/Indentation
sorry guys im a beginner looking to gain more cad experience. confused on how to draw this part. I have the main hollow cylinder part down but im confused on the grooves and stuff. any help is appreciated thank you
kelly.young has edited your subject line for clarity: How Do I draw this part? (groove/indenttion)
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
What version of Inventor are you working with? Have you gone through the guided tutorials?
  • Create a Sketch
  • Make a Centerline from the Origin
  • Draw your outside profile with dimensions fully constrained
  • Finish Sketch
  • Revolve around Centerline as the axis
Attach your attempt here (might need to compress as .zip) for community experts to comment on.
Please select the Accept as Solution button if a post solves your issue or answers your question.
jhackney1972
Take a look at the screencast.  It is up to you how much detail you add to the original sketch and how much to add in later added features.  I elected to add two edge fillets in the first sketch so when I used the "Shell" command they would carry through to the inside is their size dictated it.  I also add a second feature to the outside to demonstrate.  Make sure all you feature sketches are fully constrained either with dimensions or sketch constraints.
Next time you post a forum question, please include your model(s) so those answering can answer in a more relevant way.
John Hackney, Retired
