Is there a way to set the hole callout to include the quantity of holes by default?
Solved by CGBenner. Go to Solution.
By default Inventor adds <QTYNOTE> to the hole text string.
Has somebody changed something with your software configuration?
Edit, the gotcha here is you have to use the Hole Feature and not simple extrude-cut holes.
Been in Inventor since 2020 with 2 different companies and this is the only note I've ever seen. I'd really like place the # callout before the dia symbol since I have to do that all the time
@e_frissell
You do have some control over these in the Style Manager, under your Dimension Styles, Notes & Leaders. Not sure exactly how much control, but maybe take a look here:
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
