Inventor Highlight The Drawing Line Geometry
This widget could not be displayed.
HI , guys how can i highlight the drawing like this in autodesk inventor .
Thnx
kelly.young has embedded your image and edited your subject line for clarity: Highlight the Drawing
Replies (7)
johnsonshiue
Hi! There is a less straight forward way to do that. You will need to set the "background" components to Reference components. Then set the Reference components layer to solid line but in gray color. It should work but it seems to much work just to highlight a few components in the drawing view. Do you might elaborate the need to do this? Couldn't you use Detail View to highlight the components?
Many thanks!
Software Test Engineer
i absolutely have no idea about what u r talking about. whats background component
TheCADWhisperer
The gray components in the background.
NachitoMax
If you set the background components to reference, wouldn't that affect them in the whole assembly?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Xun.Zhang
Yes, it is affect to entire assembly especially for BOM.
Another way to try, Make the one you like to highlighted invisible in the drawing and create a new sketch based on the view, project all of geometries and change the display style to gray, then, make all of those components invisible and make the highlighted one visible again, you are all set now.
Hope it helps!
Xun
jhackney1972
The easiest and most straight forward method to achieve what you desire is to use the Properties of each part or sub-assembly in the browser.  Take a look at my screencast to see what I mean.
Here is a screen capture of my result:
John Hackney, Retired
thank you so much ! i wil definetly give a try . thank you again !
