Inventor Forum
Inventor for Studying
3 REPLIES 3
estringer
257 Views, 3 Replies
Is there a resource for accessing Inventor to use as prep for testing to become an Autodesk Certified Professional? The scope of how we use Inventor at work is too narrow to use study/learn and there is no access after hours. It is hard to justify the cost of a license for continued learning at home.
3 REPLIES 3
BDCollett
in reply to: estringer
I don't believe so. You can use your work license at home so I would try and find a solution with your work.
DarrenP
No Autodesk does not offer anything like this
Your work can set up a VPN & remote desktop from your home so you use your work computer
If your company does not allow you install the software at home
Otherwise you don’t have any options unless your use a trial
DarrenP
JDMather
@estringer
Simply download and run the 30-day trial.
If you have enough experience to be considering taking the exam - 30 days should be plenty of time to hone your skills.
