Inventor FEA of sliding square tubes with a pin in center
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So, its quite some time since I have fiddled with Inventor FEA, but I have this frame that is to be loaded in the center with enough weight that the pin has a safety factor of 2 (s235 steel)
I have taken out the 50x50x3 square tube with a 10mm hole in center, and the 40x40x3 square tube that is to be sliding inside with the equalent hole.
50x50x3 square tube is fixed in bottom, the 40x40x3 is sliding. The pin OD10mm is the part that keeps the inside square tube in place and dont let it slide. Question is what force is required to keep a safety factor with S235 steel.
Ive used force of 2000N on top of the 40x40x3 tube, only bonded constrains. but displacement do not seems correct, and the stress seems a bit to little.
Does anyone have any input? How do I upload the file, with the FEA part?
