Inventor error: "The attempted operation did not produce meaningful..."
What does "The attempted operation did not produce meaningful intersection edges from the face to face intersection. Try with different inputs" mean.
A solid extrudes successfully in one direction but for some reason I can not reverse the direction.
I have been told that your company is providing technical support to our company but see not way to contact you directly. Can you help on this issue as well?
sergio.bertino has edited your subject line (Mechanical Engineer) for clarity.
leowarren34
Can you send us any images or files of the piece you are working on?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
kgilham
Hi BBeck,
Would you be able to attach the part you are having an issue with.  That would help us diagnose the problem. If you can't share publicly let me know and I can set up a onedrive folder you can share it with us directly.
Kyle Gilham
Customer Advocacy Manager
PaulMunford
Could it be a cut extrusion?
Whoever administers your Autodesk software for your company should be able to help you contact Autodesk support.
Otherwise, you could start here:
https://www.autodesk.co.uk/company/contact-us
Paul Munford
Technical Onboarding Architect
Linkedin
