Message 1 of 9
Inventor Dynamics Simulation (Force Location)
07:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As i going deeper in deeper in Inventor I now finally beginning to understand why many Solidworks user that previously use inventor says that Inventor is a 5 years old behind. As of today i'm doing a dynamic simulation and i found out that dynamics simulation does not make sense because i cannot select a face where i will put a force but instead i can only pick vertex, circular edge, arc edge, sketch point, sketch circle, sketch arc, line end point, work point. If i select the outside circular edge it will be offset at the center plane which create a moment which is not desired, unless inventor hiding a way to do it. (most of all its not a user Friendly)
