I forgot to mention that I must have all attributes in the titleblock remain intact, including the attribute name and tag. The drawing resource transfer wizard doesn't seem to transfer AutoCAD blocks. After I convert my IDW's to IV DWG's, I can copy/paste the blocks into it, but when I insert it, there's no way to locate the titleblock (it's like I'm bring in a sketched symbol). I'm following the procedure in the help file exactly. It works great for the first sheet because the template has the block already inserted at the proper location, but when I create a second sheet, there's no titleblock. So insert it from the AutoCAD blocks section, and yet again, I can't place it precisely. There has got to be a better way to do this. I need a procedure.
Brian
