Hello all, I have a model (-6-00-00-R-500) with a constraint "DRIVE VERKOOPKLEP". It's purpose is to open and close the "-6-00-35-L-000 Verkoopklep". When I drive the "Verkoopklep" the cylinders attached to it are turning upside down and it only closes to an 89 degree angle out of the 90.
My workflow: I put the cylinder in the largest position. I than opened the cylinder and remove the constrain so it can move in and out. I did the same for the smaller “Klepsteller” on the “Neervalklep”. I than made a drive constraint and it doesn’t work all the way.
However, when I remove the constraint and drag my mouse it works most of the times, but sometimes the “Neervalklep” will rotate to the wrong side. Also when I remove the cylinders it seems to work fine, however I need them to be in the model. Yesterday I have been looking for a few hours and I can’t find my mistake, could anyone point it out for me? Or is there a way to limit the turn radius of the cylinder parts so it doesn't flip over again? I have attached a zip-file of the model, please note that the chassis and the showcase have been removed so the file wouldnt be too big.
Solved by j.palmeL29YX. Go to Solution.
In general this is related to bugs in constrain solver and it is very long lasting issue in Inventor.
Flexibility in general is very unstable and most often produces error results in assembly positions.
This subject is extensive, and unfortunately I am not able to look in to your particular data set due to lack of time right now.
there are forum threads that will give you beater overview of what you have to deal with:
Flexibility not working properly in inventor - BUG that has been there for ever
BUG that as been there for ever - Flexibility not working and Constrain solver bugs - continues
@jeffreyQ4RGW wrote:
...open and close the "-6-00-35-L-000 Verkoopklep".
First: I can't find a "-6-00-35-L-000 Verkoopklep", only a "-6-00-35-R-000 Verkoopklep". Did I miss something? Or is it only a typo?
Second: I can not see what you're reclaiming about. Here it seems to >>work well<<.
Do you use the current Inventor version (AFAIK 2022.3.1, build 350)?
BTW: Are you aware of the collision?
Jürgen Palme
I recommend that you limit your comments to actual datasets.
Ok, now I see it too.
Until now I did not yet find a solution how to avoid that. Except - You should try not to use this problematic flexibility ...
Jürgen Palme
Could you suggest an alternative than?
Restructure the assembly, so that the parts you want to move/drive are in the highest (the main-) assembly level (not "hidden" in sub assemblies). Similar as shown >>here<<.
I know, that is not comfortable (I hope this suggestion doesn't provoke a shirt storm) and causes a lot of effort, but if you urgently need this "functionality"(?). You have to decide for yourself if this can be an acceptable alternative for you (I don't know your complete project. You would have to do this consistently for the entire model.)
Jürgen Palme
Update: I took apart every assembly that was rotating in any way and constraint them back together as parts (hinges and cylinders). It seems to work. Although I had to remake my representation positions, but they also work again now.
To organize it all i made folders with the name of the assembly so I don't have 10 times the amount of parts in the browser as before.
Thank you for your tip Jürgen!
Your >>here<< link doesn't work
nope, the link works (in the meantime). Apparently Autodesk's server still was busy creating the video.
But that has now become unimportant. You understood me correctly even without the video 😉
Jürgen Palme
