Inventor Drawing View Will Not Change Model State
I've modeled a part in Inventor that will be cast and then have certain features machined(slots, drilled/tapped holes, etc). I'm using the new model states feature in Inventor 2022 to show the part as cast and then the master model state to represent the final, machined part.
Now I need to create separate drawings, one for the part when it's cast and another drawing to detail the machined part and features. On Friday, I started a new drawing file and added a view choosing the model state for the cast part then creating projected, section, and iso views from the base view. All of the views were shown in the Cast Model State with no problem and I even added most of the dimensions to the drawing without any problems. I saved everything, shut down for the weekend then come Monday morning I go back to the drawing to continue working on it and all of the views switched to the Master Model State. I checked the part file and the Casting Model State is still there and in the Drawing View Dialog Box>Model State Dropdown menu the casting model state is still an option. I tried editing the view and choosing the Casting Model State but when I do so the drawing goes to a Raster View>I click OK and it stays in Master Model State. When I open the Drawing View Dialog box the Model State has reverted back to Master again.
Additionally, all of the views need to be in the Casting Model State but are stuck in the Master Model State. The view I've been trying to change is a Parent View. In an attempt to get the correct state showing I've also tried creating a new design view in the part file then choosing it in the drawing and trying to make the representation Associative, both of which have not worked. If I try to edit a Child view the Model State dropdown is grayed out and showing Master. If I choose a Design View other than Master than the Associative check box is available. When the Master Design View is chosen then the Associative check box is also grayed out.
Can anyone explain why the drawing will not switch Model States and how to get the Model State I need to stick in the drawing?
Thanks in advance!
