Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Inventor Custom Revision Alphanumeric Method
zdalessioLRXTU
zdalessioLRXTU
Hello all.
I have a question for you. The small engineering firm that I recently employed me does not yet have Vault set up, and I have stressed the importance of implementing it ... but it seems to be gaining traction very slowly... I know I can find a solution to my particular issue with Vault, as I have set up the schemes/workflows/etc. for previous employers utilizing Vault. Since that isn't the case here, I have found myself in a particular situation where I cannot answer what should be a relatively easy problem - I would think.
This firm operates on an alphanumeric approach to revisions. "Rev 0" here is "00", following that is "0A" until it runs its course 25 iterations later to "0Z" and will then become "1A" and continue.
As far as I can tell, Inventor only allows for either: a) manual input for rev control/advancement in iProperties and manual edits to the Rev Table as they occur, b) the choice to use either alpha or numeric for Rev definition if relying on the revision table to populate the subsequent intervals as they happen.
Some of the designers here are relatively green to the field of designing in general and haven't worked in manufacturing/assembly before and have made some slip ups - we've all been there at some point, I get it, but in order to deter and reduce human-error, I reckon the best way is to remove that from the equation by driving revision updates if at all possible. Is it possible to make Inventor recognize a custom scheme or approach to revision naming/progression without the use of Vault?
I appreciate any insight any one can provide.
Thank you in advance for your time.
Eide.N
Dang, that's brutal. This isn't the answer you're looking for, but maybe it's time to update standards and move to a more conventional revision scheme.
Or, you're probably looking at a custom solution that will need to be maintained and probably expensive.
A.Acheson
Hi @zdalessioLRXTU
Yes that revision scheme is a headache but perhaps not open for discussion of changing just yet. I wouldn’t think there is any way to customize to your scheme with the available built in tools.  If I was doing this I would implement an Ilogic script with the build in scheme to count the revision rows and set the next value according to the scheme. For description have a list of standard terms, designer initials, approved etc, populate custom date scheme.
Here is a link to how this customization can be achieved
Regards
Alan
