Inventor Crashed, now I'm having issues
J-Bowers
Message 1 of 17
J-Bowers
So, I was happily using Inventor doing some cable & harness stuff when Inventor crashed on me. Now I'm having two issues:
1: When I restarted Inventor, everything opens fine and works for 1-2 minutes, then it complains about not being able to find a license. If I go to About Autodesk Inventor Professional>Product Information BEFORE it complains about no license, it shows the correct license server, Serial number, license ID etc. If I go there AFTER it complains about no license, the serial number, and license ID are blank. Sometimes, Inventor will sometimes crash when trying to view this info.
After this, I get the no license popup every 1-2 minutes.
Also worth noting, I can borrow a license no problem, but it still pops up every 1-2 minutes saying the license is borrowed.
All other users on the network are unaffected, it's just me that this is happening to.
and:
2: Whenever I try to do a nailboard drawing for any harness, all/most of the wires in that harness suddenly turn to dangling wires(red label, yellow triangle). If I open the model, the wires update and are fixed and no longer dangling. When I switch back to the drawing, Inventor crashes again.
Something seems corrupted.
Win 7 Pro 64
Inventor Professional 2017
Build 256, release: 2017.4.2
Inventor installed as part of Product Design Suite Ultimate, all the other apps in the suite work fine.
Single server network license with multiple users, no one else is affected
Replies (16)
Message 2 of 17
Cadmanto
Did you restart your PC?  Or are you just going right back into Inventor?
Did you send a report when it crashed?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 17
J-Bowers
Sorry, I knew I forgot some info.
I have restarted the PC a few times now. As well as the license server. Stop/start/reread license file and all that.
I did not send a crash report.
I also attempted both a repair, and a reinstall from the Windows control panel. No effect.
Message 4 of 17
Cadmanto
When did you last upgrade?
I am wondering if for some reason it is seeing an old version and getting confused.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 5 of 17
J-Bowers
Before 2017 we had 2014.
We've been using 2017 for over a year now with no issues.
2014 is uninstalled, and has been for several months.
Message 6 of 17
Mark.Lancaster
@J-Bowers
Is your Inventor based on an suite installation?  Do you have different suite products in your license file?
Mark Lancaster
Message 7 of 17
J-Bowers
Yes. It was installed as part of Product Design Suite Ultimate 2017.
The other products (I.E. AutoCAD) seem to work fine with no issues.
Also, I just submitted a crash report related to the cable & harness wiring crash.
Message 8 of 17
Mark.Lancaster
@J-Bowers
But do you have other suites in your license file?
Mark Lancaster
Message 9 of 17
J-Bowers
Ah, sorry I misunderstood.
Yes, there are several things on our license file.
Using licenseparser.com with our license file it's showing:
Package: Autodesk CFD
Autodesk CFD 2018
Autodesk CFD 2017
Autodesk CFD 2016
Autodesk Simulation CFD 2015
Autodesk Simulation CFD 2014
Package: Autodesk CFD Design Study Environment
Autodesk CFD 2018 Design Study Environment
Autodesk CFD 2017 Design Study Environment
Autodesk CFD 2016 Design Study Environment
Autodesk Simulation CFD 2015 Design Study Environment
Autodesk Simulation CFD 2014 Design Study Environment
Package: Autodesk SimStudio Tools R3
Autodesk SimStudio Tools 2016 R3
Autodesk SimStudio Tools 2016 R2
Package: Autodesk Vault Professional
Autodesk Vault Professional 2018
Autodesk Vault Professional 2017
Autodesk Vault Professional 2016
Package: Autodesk Product Design Suite Ultimate
Autodesk Product Design Suite Ultimate 2017
Autodesk Product Design Suite Ultimate 2016
Autodesk Product Design Suite Ultimate 2015
Autodesk Product Design Suite Ultimate 2014
Package: Autodesk Product Design Suite Premium
Autodesk Product Design Suite Premium 2017
Autodesk Product Design Suite Premium 2016
Autodesk Product Design Suite Premium 2015
Autodesk Product Design Suite Standard 2014
Autodesk 3ds Max Design 2014
Autodesk Navisworks Simulate 2014
Package: PD Collection
Autodesk Inventor Professional 2018
Autodesk Inventor Professional 2017
Autodesk Inventor Professional 2016
Autodesk Inventor Professional 2015
Autodesk Inventor Professional 2014
Autodesk Navisworks Manage 2018
Autodesk Navisworks Manage 2017
Autodesk Navisworks Manage 2016
Autodesk Navisworks Manage 2015
Autodesk Navisworks Manage 2014
Autodesk AutoCAD 2018
Autodesk AutoCAD 2017
Autodesk AutoCAD 2016
Autodesk AutoCAD 2015
AutoCAD 2014
Autodesk AutoCAD Electrical 2018
Autodesk AutoCAD Electrical 2017
Autodesk AutoCAD Electrical 2016
Autodesk AutoCAD Electrical 2015
AutoCAD Electrical 2014
AutoCAD ecscad 2014
Autodesk AutoCAD ecscad 2014 R2
Autodesk AutoCAD Mechanical 2018
Autodesk AutoCAD Mechanical 2017
Autodesk AutoCAD Mechanical 2016
Autodesk AutoCAD Mechanical 2015
AutoCAD Mechanical 2014
Autodesk AutoCAD Architecture 2018
Autodesk AutoCAD Architecture 2017
Autodesk AutoCAD Architecture 2016
Autodesk AutoCAD Architecture 2015
AutoCAD Architecture 2014
Autodesk Factory Design Utilities 2018
Autodesk Factory Design Utilities 2017
Autodesk Factory Design Utilities 2016
Autodesk Factory Design Utilities 2015
Autodesk Factory Design Utilities 2014
Autodesk 3ds Max 2018
Autodesk 3ds Max 2017
Autodesk 3ds Max 2016
Autodesk 3ds Max 2015
Autodesk 3ds Max Design 2015
Autodesk 3ds Max 2014
Autodesk ReCap Pro
Autodesk ReCap 360 Pro
Autodesk ReCap 360 Ultimate
Autodesk ReCap 2015
Autodesk HSMWorks Premium 2017
Autodesk HSMWorks Professional 2016
Autodesk HSMWorks Professional 2015
HSMWorks Ultimate 2018
Autodesk HSMWorks Ultimate 2017
Autodesk HSMWorks Premium 2016
Autodesk HSMWorks Premium 2015
Autodesk Inventor HSM 2017
Autodesk Inventor HSM 2016
Autodesk Inventor HSM 2015
Autodesk Inventor HSM Ultimate 2018
Autodesk Inventor HSM Pro 2017
Autodesk Inventor HSM Pro 2016
Autodesk Inventor HSM Pro 2015
Autodesk Nastran In-CAD 2018
Autodesk Nastran In-CAD 2017
Autodesk Nastran In-CAD 2016
Autodesk Nastran In-CAD 2015
Message 10 of 17
Cadmanto
Ok, so you say you have been fine for about a year.  Have you done other cable harnesses with no issues?
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 11 of 17
J-Bowers
Yep. I've done several harnesses over the past several months with no issues. (Other than the occasional crash, which seems about normal for Inventor)
Everything was working fine until the crash. Now I'm having the licensing and constant crashing issues.
Message 12 of 17
Cadmanto
I am starting to wonder if this particular harness somehow when it crashed, corrupted the file giving you what you currently have.
My only other thought is wondering if there has been any major improvements software downloads or updates that have happened recently that might have caused this.
Speaking of updates, you are up to the latest with yours, right?
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 13 of 17
Mark.Lancaster
@J-Bowers
How Inventor licensing works since you have a multiple types of license.
When Inventor or Inventor Pro is launch under you condition, Inventor always grabs the lower license or license associated to Inventor standard.  When you start using Inventor Pro functions it tries to swap out Inventor standard license with an Inventor Pro license.  When it can't be accomplished a message is issued stating there's no license available.   However in the Inventor 2017 release there was a licensing issue.  https://synergiscadblog.com/2016/06/21/cascading-order-of-autodesk-inventor-professional-network-lic...
In the end make sure all users using the 2017 version that they must have all the latest updates or the incorrect license is pulled and you may run out of license.   Granted this has nothing to do with the crashes but it may sort out your licensing aspect.
Mark Lancaster
Message 14 of 17
J-Bowers
Yessir, I'm vaguely aware of how Inventor uses cascading licensing. (I was not aware that it always grabs top tier license upon launch, tho.)
What's interesting is that when I first launch Inventor, I can see that I'm issued the "ultimate" license. (Evidenced by the License ID of "86689PDSU_2017_0F" in the license manager on my workstation, as well as looking at LMTOOLs on the license server) But then 1-2 minutes later I get the license error.
Also, looking at the LMTOOLS on the license server I can see that there are still plenty of ultimate, premium, and standard licenses still available to be issued when I'm getting this error.
Message 15 of 17
J-Bowers
Yeah, that's kinda what this feels like. I'm just unable to articulate it very well.
We have had no major updates or changes recently.
We are on version 2017.4.2, but Autodesk shows that there is a version 2017.4.7 available, but when I click the link I'm taken to my product updates page saying there's no updates available...
Message 16 of 17
J-Bowers
I'm just going to restore my PC from a backup a day before the crash happened. I've already lost way too much time to this.
Message 17 of 17
johnsonshiue
Hi! Could you send me an email ([email protected]) directly? I would like to take a look at the crash report and understand the issues better.
Many thanks!
Software Test Engineer
