Hi
I do that all the time.
The method I use is just to "save copy as" with another assembly name.
eg my original assy might be 18-0095-01-001-C
I will save copy as 18-0095-01-001-D, open that one and work on it.
That way the links are still kept, the original is still kept with its original name.
You can then just do a "component replace" or component replace all"
for the parts you want to replace, if the new parts are very similar,
or simply delete the unwanted parts and insert and constrain the new parts.
Works very well, I have been doing it for years
I only use pack and go when I want to make a copy of my idw's to another location and bring with
the idw all the linked ipt's, iams, etc.
The pack and go, sort of acts as an old or superseded copy, if you do updates on your original copies,
because these updates won't show in the location where you have "pack and go"ed.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Higher Diploma Mechanical Engineering
Certified Autocad 2013 & Inventor 2013 Professional
Authorised Autodesk Trainer
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
