Inventor Content Center Nyloc Hex Nuts Available Under Different Name?
spl1970
Message 1 of 14
spl1970
OK, so I'm going to be lazy as I've had a quick look and I can't find it. Are Nyloc nuts available in content center under a different name?
Cheers,
Simon
kelly.young has edited your subject line for clarity: Content Center query
Replies (13)
Message 2 of 14
Lewis.Young
Hi Simon,
Yes, if you search for "prevailing torque" you should see the different types or locking hex nuts.
Lewis
Message 3 of 14
Cadmanto
Simon,
Truthfully, never got my Nyloks from the CC.  Always went to McMaster-Carr and down loaded the model from there.
https://www.mcmaster.com/#nylock-nuts/=1dzspop
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 14
spl1970
Wow, that's quite a resource there Scott, many thanks.
Simon
Message 5 of 14
spl1970
Thanks a lot Lewis.
Message 6 of 14
swalton
I don't normally use McMaster hardware because they model the threads.  Not helpful in large assemblies. They don't have iparts for download that I can find, which makes it difficult to change fasteners during the design phase.
I got most of my hardware as iparts from Charlie Bliss's web site, here: http://www.cbliss.com/inventor/Parts/Fasteners/index.htm
Steve Walton
Inventor 2025
Vault Professional 2025
Message 7 of 14
spl1970
Thanks for the info, although the parts won't be of much use to me as they're imperial, but the other areas of that site may well be.
Simon
Message 8 of 14
SBix26
Just piling on, here...
From Wikipedia: "Nyloc" is a registered trade name of Forest Fasteners.[2] In Australia "Nyloc" is a registered trade mark of Exafast Pty Ltd.
Just as with BAND-AID®, Kleenex® and many other items, the trade name of the first or biggest product may end up being used to refer to the entire class of products, but technically/legally it's not correct.
Sam B
Inventor Pro 2019.1 | Windows 7 SP1
LinkedIn
Message 9 of 14
spl1970
Thanks for pointing that out Sam, I was aware of that but for the purposes of asking a question on a forum I thought it would be OK to use a term that is popular and well known. Hope the lawyers stay off my back.
Message 10 of 14
SBix26
I hope so, too!  Just pointing out why you wouldn't find them listed in the Content Center by trade name (even though under Sheet Metal > Nuts you will find nothing but PEM® brand swage nuts...).
Sam B
LinkedIn
Message 11 of 14
I have downloaded the file and opened, stored the zip file contents.   Can you give guidance on how to specify a specific nut size and import to Inventor assembly?  Thanks.
Message 12 of 14
swalton
Try http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-ACDA3A15-8B70-42B1-814C-50A60B79A09F
You may need to open the ipart factory file and drag the End-of-Part Marker to the end of the browser to make sure the geometry is computed before your first use.
Steve Walton
Inventor 2025
Message 13 of 14
liam.dewhurstNMKYG
Did you ever find a metric version of the Nylok part?
I'm 3 years in the future, and on the hunt...
Message 14 of 14
SBix26
DIN EN ISO 10511, 10512, and 7040 are plastic-insert prevailing torque nuts (aka Nyloc).
ANSI also has a metric version, with both all-metal and plastic-insert types:
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
