- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
After a bit of thought I’ve decided to do a write up on issues with item numbers in Inventor drawings. My reasons for this are that I want to know if there any ways to do what I want to do that I haven’t discovered, describe some current methods that some of you might find useful, and get support and/or criticism for a new feature that I am going to present.
As a draftsman with 4 years + experience with Inventor, I have come to know the program fairly well and regard it highly.
There is however one major flaw with the drawing environment: The inability (there are workarounds, which I will get to shortly) to attach an item number to component detail views that reference the BOM of their parent assembly.
This may seem trivial, but is a subject that keeps coming up, not just from Inventor users but also from other design office personnel, allocation staff and manufacturing workers.
I won’t rule out the possibility that this feature exists (if it does, please enlighten me!), but I would like to know why such an important feature has been omitted. Legal/copyright reasons? Marketing reasons? It’s not possible to program it that way? Not seen as important? In development?
Whatever the case, I will now discuss 3 workaround methods, followed by my own suggestion as to how I believe this feature could/should be included.
Method 1: iProperties Item Reference
Using this method, the item column and item bubbles reference an iProperty (such as Part Number or Stock Number) rather than the Item Number found in the BOM. A base view of an assembly is placed on a drawing, followed by base views of its parts. A parts list referencing the assembly is then created, and item balloons are attached to all parts on the assembly view and all component base views.
Advantages of this method include:
- Ability to attach item balloons to each component base view.
- Ability to include the item number in component view labels.
Disadvantages include:
- Item numbers must be entered manually.
- Item number is an iProperty; if a component is being used in multiple drawings, it retains its original item number. If the item number is changed to suit a new drawing’s BOM, the original drawing’s BOM will also update.
- Does not allow for automatic renumbering in the parts list editor.
Method 2: Component View Representations
In the assembly, a new view representation is created for each component, in which visibility for every other component is switched off. A base view of the assembly is placed on a drawing with the relevant view representation selected for each part detail.
Advantages:
- Allows ballooning of component views using BOM Item Number.
- Quantity can be added to balloons and view labels.
Disadvantages:
- Creation of view representations is time consuming.
- A new view representation must be created for each new component.
- Visibility of newly placed components must be manually deselected.
- iProperties in view label reference parent assembly
- Inability to detail flat pattern views.
Method 3: Weldment Detail
This method is similar to the view representation method, however the views are created automatically. It has the disadvantage that a weldment must be created for it to be of any use; as such it has no use for fastened assemblies that require component details.
These 3 methods all have their pros and cons, and really only appear to be workarounds for the problem at hand.
Now to my suggestion:
COMPONENT VIEWS
First, a standard base view of an assembly is placed on the drawing.
In the drawing environment, on the views panel of the drawing tab, there will be a button titled “Component Views”.
Pressing this button will bring up a prompt that says “select source view”.
The user then clicks on the base view on the assembly, and a dialogue box appears.
The box has a list of the assembly’s components, each next to a check box. The user then checks the required components, or checks “select all”.
The user then places each component view 1 by 1, selecting orientation as they go.
Item balloons can now be added to the component views; the number reflects the item number in the parts list of the parent view.
BOM data can also be added to the view label via “BOM Properties” in the drop down menu, and “Component Properties” references the iProperties of the component; Model Properties still allows the parent assembly to be referenced.
The component view can be turned into a standard base view by right clicking it and selecting “convert to base view”. I would also endorse the possibility of converting base views to component views.
I’m no expert on the programming side of things, but I don’t see why this isn’t possible; all the information is there, it seems like it’s a matter of getting it all in the one place.
Please let me know what you think about the component views idea. Preferably quote one of the following points
- Great idea! Autodesk, take note.
- Sounds good, but needs more thought.
- Not that important, but it can’t hurt to have it.
- Some good points, but lots of flaws; I am happy without it.
- No good, completely unnecessary / totally flawed.
Thanks for reading, constructive criticism is greatly appreciated.
