Inventor Closed And Did Not Prompt For Save, Did Not Save Work Done
just closed an assembly, and normal Inv. asks to save. Well he didn't and jumped back an hour of work. I tested it again to check if I was right, and I was. Inv. did not ask to save when closing an assembly, until I restarted Inventor completely. Then it went to normal again.
kelly.young has edited your subject line for clarity: ...did not save
YannickEnrico
You may have accidentally clicked here.
Edit: On the <<prompts button.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Cadmanto
Depending on how you have this set,
Will speak to how up to date the file(s) in your "Old Versions" folder are.  You may not have lost as much as you think.  Check your old versions folder and see how recent the file(s) are.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
But doing so shouldn't cause any loss of work...
johnsonshiue
Hi! Indeed, when files are changed, Inventor should always prompt users to save. If you can reproduce the behavior, please let us know the steps.
Many thanks!
Software Test Engineer
