Inventor changing view when creating part or modling in assembly
eddyen1983
Message 1 of 8
eddyen1983
How to stop inventor turning view around and going to a some kind of default view, when entring parts modling from assembly or creating a part in asssembly
Replies (7)
Message 2 of 8
jnowel
is that happening when creating/editing a sketch?
you may need to uncheck this portion in the Applications Options.
edit: i think it would be the "In Part Environment" instead
Message 3 of 8
johnsonshiue
Hi! There is another place to change in order to avoid automatic Isometric View on creating a new sketch. Currently there is no option to suppress the behavior except making one of the origin planes visible in the template file or preselecting a planar face before creating a 2D sketch.
Many thanks!
Software Test Engineer
Message 4 of 8
rosie_lucas1
Hello @eddyen1983
Did the information provided by @jnowel and @johnsonshiue help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Message 5 of 8
eddyen1983
I dont  think this helps
Message 6 of 8
eddyen1983
Message 7 of 8
jnowel
i believe you can untag/unaccept the solution if that didn't help.
if you can elaborate further on the issue so we can help understand your issue.
maybe provide a video on what and how it happens to be clearer.
Message 8 of 8
eddyen1983
This is possible a solution. But autodesk need to make change in setup so that it could be turned off
