Inventor Change Text Leader Arrow Colors
lkirit2000
Advisor Advisor
Message 1 of 11
lkirit2000
Hi
Please see the attached image. I need to change the arrow color of text leader ?
Rgds
kelly.young has embedded your image and edited your subject line for clarity: Text Leader Arrow Colors
Accepted solutions (3)
Replies (10)
Message 2 of 11
johnsonshiue
Hi! Yes, this is controlled by Leader style. Go to Manage -> Styles -> Leader -> find the active leader style -> change the color.
Many thanks!
Software Test Engineer
Message 3 of 11
lkirit2000
Hi Johnson,
Thanks for your prompt response. Earlier I have tried that way . Created a new leader style and applied, but it hasn't come to the drawing view. Image attached.
Rgds
kelly.young has embedded your image for clarity.
Message 4 of 11
johnsonshiue
Hi! Please attach the example here. It should work. Either the correct style was not changed or there is a bug.
Many thanks!
Message 5 of 11
lkirit2000
Please see the attached file.
Rgds
Message 6 of 11
johnsonshiue
Hi! Like I suspected, you change the leader style which is not associated with the leader. The active leader style in your file is actually "General (ANSI)", not "Alternate (ANSI) - RED COLOR."
Many thanks!
Message 7 of 11
lkirit2000
Hi
General ANSI is belong to the leader, but when I change the color, the weld symbol leader also change. But I need to change Text Leader only.
I created a new leader style from General ANSI and changed the color to Red, But I don't know how to apply this New Style to Existing text leader.
Rgds
Message 8 of 11
kelly.young
Autodesk Support
Autodesk Support
Hello @lkirit2000 you are very close,
Style Editor > Dimension > New Style (Copy of).
Change Notes and Leaders > Leader Style to the one you created Alternate (ANSI) - RED COLOR
Is that what you're trying to accomplish?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 9 of 11
lkirit2000
Hi Kelly,
Thanks for your response. Job Done !
Rgds
Message 10 of 11
johnsonshiue
Hi! Another way to do that is to create a new layer with red color. Then assign the annotation to the layer instead of the default layer.
Many thanks!
Message 11 of 11
kelly.young
Autodesk Support
Autodesk Support
Good idea @johnsonshiue you could change the layer and then change the text color.
