Inventor Change Color of Unconstrained Line
Message 1 of 12
Hi everyone!
How can i change the color of the unconstrained line to a green color so that it is easily seen if it is not constraint thanks.
kelly.young has edited your subject line for clarity: Inventor Color
Replies (11)
Message 2 of 12
YannickEnrico
Options -> Colors -> Color Scheme.
Not sure you can change the colors individually. But you can change the color scheme, which changes the background color as well as the line colors.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Message 3 of 12
Hi!, Yannick I do not like to change the color scheme, the sketch color is what i would like to change. Thanks for your reply.
Message 4 of 12
mcgyvr
You can use the "Inventor color scheme editor" to change individual elements and even make your own complete color schemes..
https://www.cadlinecommunity.co.uk/hc/en-us/articles/115004326885-Inventor-Color-Scheme-Editor
Message 5 of 12
mertcanavsar
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
I think there are no options for changing color. Only line color (like AutoCAD layer) changes.
Message 6 of 12
mcgyvr
That information is wrong..
This is mine for Winter Night in 2018..
Red is under constrained lines... the purple is constrained lines..
You can change those to whatever you want..
This is a screenshot of the "Inventor Color Scheme Editor" that I talked about above and the link shows how to install it
Message 7 of 12
mertcanavsar
Yes, my information is imperfect. But I mean there are no options in Inventor settings. Your solution is another application and it is a good solution.
Message 8 of 12
I wonder why inventor sometimes does not make it straight to the point.
Message 9 of 12
I did try it but hmmmSmiley Sad it didn't work.
Message 10 of 12
Im using inventor 2018 on a windows 10, I did try the link provided by
Message 11 of 12
mcgyvr
Make sure you are picking the correct registry version (if you have multiple versions of Inventor)  AND that the selected color scheme is the same one you are using in Inventor.. (tools..application options... colors tab
2018 is Registry version 22..
Its working just fine for me..
Message 12 of 12
