Hi
Refer the sketch below, along the top right edge I need have chamfer, but size is narrows with the distance ( converges ).
What is best way to do this ? Please explain ?
Rgds
kelly.young has edited your subject line for clarity: Converging Fillet
Hi! Is this a school assignment? If yes, I would suggest you talk to your teacher first. I can give you some hints. In this case, Chamfer command will not give you the desirable result. There are multiple ways to do that. You will need to consume the sketch and the operation should be cut.
Good luck!
Many thanks!
@lkirit2000 wrote:
... I need have chamfer,
Your title says Fillet, but your problem description says Chamfer?
Which is it that you need?
Can you attach your *.ipt file here?
