Inventor Can't Place VEX Cortex Into Assembly Unresolved Sub Cyclic Dependencies
Message 1 of 11
I am making a design of my VEX robot, but when I place the Cortex into my assembly it gives me this error message:
"The selected assembly contains one or more unresolved subassemblies. Due to the possibility of cyclic dependencies the requested operation is not supported."
How do I fix this?
Attached is a picture of my folder.
Thank you so much for your help!!
kelly.young has embedded your image and edited your subject line for clarity: Can't place VEX cortex into my assembly
Replies (10)
Message 2 of 11
Frederick_Law
You need to open the assembly and resolve it first.
Make sure your project is correct.
Message 3 of 11
I forgot to add that these are the unresolved components in my VEX cortex. So how do I resolve the issue?
Message 4 of 11
Mark.Lancaster
@Anonymous
You are missing those files or you put them somewhere else that Inventor is unable to locate them..  Are you sure you have all the related files for this assembly?
Mark Lancaster
Message 5 of 11
I downloaded the VEX parts again from the website, and even made a new folder to put it in, but still didn't fix it. So why don't I have that component?
Message 6 of 11
karthur1
I order to resolve this, before you open the file, click on the "Open with Options" under settings on your Home Screen.  Un-check the "Skip all unresolved files".
Now when you open it, it will give you an opportunity to locate the file.  It should located under the scope of your .ipj.
Message 7 of 11
Mark.Lancaster
@Anonymous
I have no clue about this school project or what is offered or what's in that folder.  You have to remember this is mainly a forum where commercial projects are being made and most of us don't have insight to what school projects or files are out there.  Don't you have an instructor or mentor regarding this?
Mark Lancaster
Message 8 of 11
WHolzwarth
Perhaps this file does it. I've seen it in VEX Robotics - Metric/Logic/Components folder
Walter Holzwarth
Message 9 of 11
This is not a school project. I just want to build my robot in Inventor. The parts I get are from the Autodesk website from this link, https://www.autodesk.com/education/competitions-and-events/vex/recommended-software#Kit-of-parts. Under Download the VEX Kit of Parts section, Inventor_2013_VEX_KOP_-_Imperial.zip.
Message 10 of 11
Frederick_Law
Try put the folder with all the files into your Project Workspace folder.
Message 11 of 11
Thanks! It's weird why they don't include that in the Imperial version.
