Inventor assembly reference in drawing view tree
AlejandroAvila01
AlejandroAvila01
While doing an inventor drawing on the tree, it wouldn't show any assembly that is referring any view.
Tried to close and open drawing. Wouldn't work. Any suggestion?
As you see it is correctly resolved, so I don't think that would be a problem at all.
Gabriel_Watson
When in doubt:
1- Rebuild All in your assembly;
2- Inventor Reset Utility in Start Menu (save your settings from App. Options > Export beforehand).
johnsonshiue
Hi! This is absolutely wrong. Try this and see if it works better. Go to Control Panel -> System -> Advanced System Settings -> Environment Variables -> create "DYNAMIC_LOAD_APPLETS" and set it to 0. Restart Inventor and exercise the workflow. This variable forces Inventor to load all core dlls on startup, as opposed to loading on demand based on document type. Does it work better now?
If not, please zip up the files and send it to me directly [email protected].
Many thanks!
Software Test Engineer
