02:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hey guys. I want to design a portal frame however i don't how the best method to use in order to design a portal frame which is parametric.
What I'm thinking is to make all the parts at the first, bottom flange, top flange, web, plates etc. Then make an assembly of the portal frame and the last the drawings.
Would you suggest the same? Because i want to use the files again and make another portal frame by just chaning the dimensions.
kelly.young has edited your subject line for clarity: Portal frame design
Link copied
